Latest post Thu, Mar 29 2018 7:50 PM by JPBU. 2 replies.
  • Sun, Dec 10 2017 12:26 AM
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 135
    • Points 1,830
    Upstream pipe stall on Transcode
    I'm transcoding linked footage from 1DX MKii (big files, like between 2gig and 120gig each)... From 2min to 30min. I get inconsistent "UpStream PipeStall" on some clips... Sometimes I retry and it works, sometime not. I've tried of different drive (RAID 0, RAID1, and USB3 regular BU drive) but I can't really see any difference.
    Any idea what cause this?
    CONSOLE EXCERPT:
    [CATEncodeCvtr 0x7fb868197a00] AsyncExec::CheckIfReadyToExecuteByInput(sample 1427, exec tag 1428) - returning false
    Still waiting on input 0 (slot 0), state No Progress Made
    [CDCIWriter 0x7fb859a59288] AsyncExec::CheckIfReadyToExecuteByInput(sample 1427, exec tag 1428) - returning false
    Exception caught in APlayer::Play - Exception: NEMFileWriter::ExecuteInternal TIMEOUT - NEMFileWriter has detected upstream pipe stall...
    Exception:
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Mon, Dec 11 2017 6:18 PM In reply to
    • Posts 10,023
    • Points 215,770
    Re: Upstream pipe stall on Transcode
    JPBU
    Check your internal media drive and see what MB/s read speed you are getting off of it.
    Copying one file to your other media drive just to test, and if it works then it might be your internal drive where the app resides.
    Sorry edited as I copied the wrong file.
    Are you able to turn the processor priority to low for MC and set the core affinity onto only one core instead of the multiples you may have.  For many this resolved the issue.....
    also are you using USB 3?
  • Thu, Mar 29 2018 7:50 PM In reply to
    • JPBU
    • Canada
    • Posts 135
    • Points 1,830
    Hello Marianna. Sorry, I've never seen your reply.
    A few months later and I'm still having the same issues. Both of my drives are Thunderbold 2- Raid 0.
    Could you share with me a link that explain how to  turn the processor priority to low for MC and set the core affinity onto only one core.
    Thanks.
