Latest post Sun, Dec 3 2017 9:47 PM by AndrewAction. 16 replies.
  • Fri, Dec 1 2017 1:36 PM
    • Avidator
    • Joined on Mon, Oct 23 2017
    • Posts 19
    • Points 225
    Audio Export - Bad Quality
    it's days now and i can't figure it out. When playing back my sequence with music audio in timeline audio is fantastic. After exporting my sequence audio is always of bad quality. Export Setting is QT h264and at first i tryied with AAC compression than without any sort of compression (didn't select audio in otions) but same result. I've tried with the two mono channel and then with one stereo channel and same result.
    Anyone can help me or have an idea why this is happening?
  • Fri, Dec 1 2017 2:02 PM In reply to
    Re: Audio Export - Bad Quality
    Which specific version of Media Composer are you using? What are your system specifications? When you say "bad quality" what do you mean?
  • Fri, Dec 1 2017 2:30 PM In reply to
    • Avidator
    • Posts 19
    • Points 225
    I'm using 8.4.5 on a Mac.
    When listening in the timeline, audio is good like original file. Exporting, is like if sound is lower and the low frequencies are almost gone
    Here file .mov with just audio
    http://jmp.sh/v/VyOZheLjuTVNfeLXkXzT
    (AMA linked, audio set multichannel audio)
  • Fri, Dec 1 2017 2:38 PM In reply to
    Avidator:
    You've posted this in the PC forum. I'll move it over to the Mac forum.
  • Fri, Dec 1 2017 4:23 PM In reply to
    Could the two tracks being monoing up and distorting?
  • Fri, Dec 1 2017 5:42 PM In reply to
    The track seems, as you say, fine in stereo, however as the piano in the recording has a lot of out of phase elements, it reduces the level of the piano if you mono the track.
    Perhaps, as Pat says, something in the export chain is summing the tracks, this would cause the change in balance and would certainly add some distortion as both channels peak at "0".
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona Lhi. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 32GB ram Aja I/O express, Apple... [view my complete system specs]
  • Fri, Dec 1 2017 11:17 PM In reply to
    • Avidator
    • Posts 19
    • Points 225
    So what should i do? Why the piano in timeline sounds perfect and than came out distorted?
    When exporting i select qt reference and only audio, in preference i don't flag audio setting so it should came out without compression i suppose?!
    anything wrong here?
  • Fri, Dec 1 2017 11:18 PM In reply to
    • Avidator
    • Posts 19
    • Points 225
    Pat Horridge:
    How could this be possible?
  • Sat, Dec 2 2017 8:58 AM In reply to
    • Avidator
    • Posts 19
    • Points 225
    The file i AMA linked is an mp3. I realized every audio file i import have the same behaviour.
    Checking the console it says: MSMRescan() took: 0.171837s
    p, li { white-space: pre-wrap; }
    Warning: 1 audio clips required Audio SampleRate Conversion.
    Please convert these files to avoid underruns and improve audio quality.
  • Sat, Dec 2 2017 9:05 AM In reply to
    Can you post a screen shot of your timeline? It might help if we could see the sequence.
  • Sat, Dec 2 2017 9:16 AM In reply to
    • Avidator
    • Posts 19
    • Points 225
    i've just tried duplicating sequence and leave just audio file. The audio original file is 44100Hz so i set project format at same Hz and now console says:
    Audio Mixdown will require 42893396 bytes. AudioSamplesInSequence= 10723349, SequenceLength= 5830, DestinationBytesPerSample= 2, numOutputChannels= 2. 41888 KB needed.
    Duplicate definition entry (not added)
    Plugin definition registration failed
  • Sat, Dec 2 2017 9:47 AM In reply to
    • Avidator
    • Posts 19
    • Points 225
    i think the problem is the mp3 file that avid doesn't like. Thanks for helping anyway
  • Sat, Dec 2 2017 7:39 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,184
    • Points 23,370
    Have you tried to do a audio mixdown and if as you say no L/F then that could be a phase issue I always do mix downs befor encoding
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Sun, Dec 3 2017 4:37 AM In reply to
    • Tiger_XP
    • Joined on Fri, Feb 2 2007
    • California
    • Posts 465
    • Points 5,130
    Avidator:
    I think the problem is the mp3 file that avid doesn't like.
    You may be on to something about the mp3. I downloaded the audio and this happened:
    1. I heard the volume you spoke of while it played in the MC timeline. Also there was a glitch @ 1:51
    2. The (wave file) exported from MC had much lower volume
    3. When exported as the other option (not aiff but somethinge else. Not on that computer with MC 8.8.0 at the moment) there was silence.
    4. When sending the original file out as an aaf there was an problem trying to import it into Davinci 12.5.6.
    5. The wave file that was exported from MC (low volume) imported into Davinci as a mono file.
    6. I did not boot into the OS that has all the music/audio apps to manipulate the file
    MacPro 2008 3.1 | 34GB Ram | Quadro 4000 980ti 960| MC 8.10 | OS 10.6.8 10.13.6 | MOTU HDX-SDI | ATTO R644| LaCie 324 [view my complete system specs]
  • Sun, Dec 3 2017 6:35 PM In reply to
    • Avidator
    • Posts 19
    • Points 225
    Tiger_XP:
    Avidator:
    So you say the mp3 it's the problem? I've tried with other 4 songs (mp3) and same result.
    Tom Pearson:
    Yes, i've tried but same result. What you mean with no L/F
    When you do a mixdown you send new audio in a new track right, and what you do with the tracks you have mixed down that remain in timeline?
