Latest post Sat, Nov 3 2018 10:29 PM by tommix. 48 replies.
Page 3 of 4 (49 items) < Previous 1 2 3 4 Next >
  • Tue, Jul 31 2018 7:05 PM In reply to
    Re: Media Composer First, Publishing Error - HELP
    Sure thing. I can just put two short clips (say 5 seconds each) into a timeline and give that project a new filename. Will that do the trick?
    Windows 10 Home Intel Core i7 5500U CPU at 2.40 GHz, 240 MHz, 2 cores, 4 logical processors 8Gb RAM DDR3 1,000 Gb HDD [view my complete system specs]
  • Tue, Jul 31 2018 10:57 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,685
    • Points 18,545
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Be sure to work on a different clips, where are trying to figure out if it's a corrupted media, also take note if it asked you for the destination folder. Thanks!
  • Tue, Jul 31 2018 11:01 PM In reply to
    Will do. It's midnight here in the UK now, so I'll shoot two new clips tomorrow and let you know the outcome.
    The thanks are all mine.
  • Wed, Aug 1 2018 7:45 PM In reply to
    I loaded two new .movs (shot on an iPhone and uploaded to my c: drive) and put them into a new project. Selected File - Publish to ... - Local Drive and got the same error message as before. It didn't ask me to specify a destination.
  • Wed, Aug 1 2018 9:35 PM In reply to
    • RalphC
    • Posts 1,685
    • Points 18,545
      Avid Employee
    Can you delete the following file?
    Delete these files. Default location is C:\Users\Public\Documents\Avid Media Composer First\Settings
    MC State
    Site Attributes
    Site Settings
  • Wed, Aug 1 2018 9:47 PM In reply to
    Done. Shall I try again now?
  • Thu, Aug 2 2018 2:40 AM In reply to
    • RalphC
    • Posts 1,685
    • Points 18,545
      Avid Employee
    Go ahead and publish? By the way did you tried to uninstall and reinstall? Are there any other harddrive USB drive connected?
    RalphC
  • Thu, Aug 2 2018 2:03 PM In reply to
    Didn't work, I'm afraid. I closed down the app and re-launched it after deleting the files you mentioned. Then I created a new project with two clips and tried to publish it but got the same error as before.
    I did uninstall and re-install shortly before I first posted to this thread. Also, yesterday the Application Manager invited me to install version 2018.7 (it spoke of "bug fixes", so I liked the sound of that ...) but however often I try to do that it won't install - it just keeps telling me I need to install, but it won't let me do so. I think what I might do now is to uninstall again and load 2018.7 from scratch, see if that makes any difference.
    I do have an external USB HDD attached sometimes, yes. But in this instance the media files I'm using are on the C drive.
  • Fri, Aug 3 2018 10:38 AM In reply to
    • RalphC
    • Posts 1,685
    • Points 18,545
      Avid Employee
    Piers Fletcher:
      We found an issue with the MC2018.7 installer, I recommend you unistall 2018.5 then install 2018.7, you can get the download via Avid master account.
    RalphC
  • Sat, Aug 4 2018 8:49 AM In reply to
    Thanks. I've done that, and the installation appeared to succeed but seems to have made matters worse. Now I can't even place a clip into the timeline at all - when I try to, I get this error message:
    Ralph, I sincerely thank you for your efforts so far but I think I'm going to give up. There's clearly something about my computer set-up that doesn't agree with the Avid software, so I think I'm just going to have to try a different program. It's a shame, because I work in Avid all the time in my professional capacity, but at the moment it's taking all my personal time just trying to get the app to run on my own equipment, and I think it'll be quicker to just learn a different system.
  • Mon, Aug 6 2018 1:44 PM In reply to
    • Posts 9,882
    • Points 214,055
    Piers...
    email me off the forum and include the link to this thread.  I have an idea here...
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Sat, Sep 29 2018 8:50 PM In reply to
    • tommix
    • Joined on Tue, Oct 14 2008
    • Posts 198
    • Points 2,430
    All versions until 2018.9 have worked perfectly. Now I join some of the rest of you.
    Now an export to Utube -- same error
    Clue: I did a mixdown of a LINKED file and it worked fine. And, the published SEQUENCE is also fine despite the publishing error. So the error comes after the Sequence file has been created.
    I did do one thing before installing 18.9 -- I emptied all these folders.
  • Sun, Sep 30 2018 1:02 PM In reply to
    I'm afraid I just gave up eventually. I dare say it's my own fault in some way, but I just couldn't get the Avid software to run, so I've gone elsewhere.
  • Fri, Oct 5 2018 6:28 AM In reply to
    I had the same problem and I found the solution was to delte the User and Project settings
    http://community.avid.com/forums/t/36514.aspx
    Media Composer then re-creates (the default) settings when you open up the software.
  • Sun, Oct 7 2018 9:44 PM In reply to
    • tommix
    • Posts 198
    • Points 2,430
    Re: Media Composer First, Publishing Error - HELP >> SOLUTION
    You do not have to give up on using MCF.
    1) Mixdown video.
    2) Mixdown audio.
    3) The two or three files will be in yourAvidMedia folder.
    4) Drop them into another NLE. I use Resolve.
    5) Export your movie as DNxHD or ProRes.
    6) If needed, upload DNxHD or ProRes to YouTube or Vimeo. Let them do the single compression to h.264/
