Latest post Tue, Nov 21 2017 11:36 PM by Vadym. 3 replies.
  • Tue, Nov 21 2017 4:16 PM
    • ding-mc
    • Joined on Tue, Nov 21 2017
    • Posts 3
    • Points 45
    Check in aaf media offline in interplay
    I have checked in an aaf using the C++ code on this forum and it is working fine but for a single problem. The media plays back fine and can be loaded fine into Media Composer but Interplay gives me the red offline dot next to it. It doesnt have a headframe yet as that is a topic for another thread. Could the fact that there is no headframe cause the offline status? Again, the media plays back fine and can be brought in to Media Composer.
    One thing I forgot, I am manually adding the mxf's to the Nexis drive's media files folder.
  • Tue, Nov 21 2017 8:34 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 211
    • Points 2,600
    • Avid Developer Moderator
      Avid Employee
    Re: Check in aaf media offline in interplay
    Manual media files management is not recommended. Please use Interplay Access to update status from Media Indexer first. If media status is still "red" check Object Inspector pane to ensure that file locators are pointing the the existing files.
    Asset headframe is kept separately from the media status and cannot be cause from the media offline status.
    The reason for media offline is most likely due to AAF you have contains incorrect media locators in it.
  • Tue, Nov 21 2017 10:10 PM In reply to
    • ding-mc
    • Posts 3
    • Points 45
    Im triying to automate this process so using interplay access is not a solution that will work for us. I am sure that the aaf file locators are most likely pointing to the wrong drive though. Will try that and see what happens. Is there an automated way to update the indexers? We are using a background process that moves the files to the appropriate drive but if there is a better way I am interested.
  • Tue, Nov 21 2017 11:36 PM In reply to
    • Vadym
    • Posts 211
    • Points 2,600
      Avid Employee
    You'll need AMT api to move media correctly. Please contact partner programs dept to request it.
    http://www.avid.com/alliance-partner-program/connectivity-program
