Latest post Sat, Nov 11 2017 3:05 PM by rodpaul. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Nov 6 2017 11:05 AM
    creating subtitles
    had and have to do a lot of "burnt in" subtitles. Normally I use title tool, but I wonder if there is a better way converting text files into subtitles, a plug in e.g.?
    SubCap does not seem to be the right answer for me, as my clients just sends me doc files without any timecode data. If I got it right subcap needs a special kind of file?
    Any suggestions?
    MC 19.07, WIN 10 x64, HP z840, dual E5-2640v3 2.6Ghz, 8x4GB RAM, Nvidia Quadro M4000, MXO2 LE, Artist Mix [view my complete system specs]
  • Mon, Nov 6 2017 4:36 PM In reply to
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 481
    • Points 6,535
    Re: creating subtitles
    See this tutorial by Douglas Bruce. He shows you hot to use Boris Red to do subtitles, but in the process he prepares the text using an app called Avisub - that might help you turn a doc file into subtitle file.
    https://www.youtube.com/watch?v=T8UQQx5YyRw
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 64GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 441.12) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Mon, Nov 6 2017 6:30 PM In reply to
    • LKJ JKL
    • Joined on Tue, Jun 2 2009
    • Posts 140
    • Points 1,645
    Michael from cologne:
    No, it doesn't. You can import files coming from a subtitling app, but you don't have to.
    I use Subcap, it's faster than doing the titles with any TT.
    You can C&P the text into a box at the bottom of the FX editor.
    HP Z420 (E5-1650v2) | 32GB RAM | 250 GB SSD (OS) | NVIDIA Quadro P2000 (driver v441.28) | internal raid0 | AJA Io Express (driver v15.5.1) | Win7 Pro64... [view my complete system specs]
  • Mon, Nov 6 2017 10:29 PM In reply to
    Yup use subcaps and cut and paste.
  • Wed, Nov 8 2017 12:45 PM In reply to
    Hi all,
    thanks for your comments. probably yes, subcap is a better option than tt, althought text editing in the master caption list is not super comfortable - but there are a lot of other benefits vs tt. will try it in depth next time. Aegisub seems also interesting for more complex work.
    Michael
  • Wed, Nov 8 2017 10:36 PM In reply to
    Love to use Subtitle Edit for Copy&Paste and TC setting. Exporting as Avid Subcap txt und using Subcap Effect.
    HTH
    pixel
    iMac Mid 2016 / High Sierra 10.13.6 / 32 GB RAM / MCA 2019.12 / MojoDX / Adobe CC 2018 / MBPro Mid 2015 / High Sierra 10.13.6 / 16 GB RAM / MC 2019.12... [view my complete system specs]
    What is editing? It´s the process of transforming a collection of badly focussed or horribly framed shots containing reversed screen directions, flare and dirt into a smooth visual statement of the script... ... for which the director takes the credit!
  • Thu, Nov 9 2017 12:23 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 591
    • Points 6,995
    what u do is dis:
    1. put subcap on an empty track, spanning whole timeline. enter a line of dummy text.
    2. remove subcap in portions that don't need subtitles.
    3. open word on second screen, resize avid to one screen.
    4. let avid play, stopping when you feel that you've heard enogh text for one subcap box. make an H cut in subcap effect.
        make paragraph in word after translation of text for dis box.
    5. ????
    6. open master caption list, copy-pasta sentence by sentence without stopping or listening.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Fri, Nov 10 2017 9:46 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Does anyone know how to make single line captions on the bottom of a two line box?  Some of my captions require two lines of text, but when I enter just a single line it appears on the top - which looks wierd. I can't seem to move it to the bottom of the text box, or whatever it's called. Otherwise subcap works great.
    Dell T3600T 12 Cores 3.5 ghz Intel 32GRAM K4200 Windows 10 [view my complete system specs]
  • Sat, Nov 11 2017 11:32 AM In reply to
    • blindpew
    • Joined on Sat, Nov 5 2011
    • Posts 45
    • Points 485
    In the Box Appearance section, go to the second pop-up menu - you have a choice of "Anchor to Bottom of text" or "Anchor to Top of text". Once you change this setting, you'll probably need to alter the Anchor Y positon as well
    freelance - hence many and various... [view my complete system specs]
  • Sat, Nov 11 2017 3:05 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Great, thanks -
