Latest post Wed, Nov 1 2017 7:57 PM by camoscato. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Oct 27 2017 3:10 PM
    • Avidator
    • Joined on Mon, Oct 23 2017
    • Posts 19
    • Points 225
    SCRIBBLE Animation
    hello I'm trying to post this question but it is not posted and i do not know why
    I try , what I want to get is an effect like this
     where the drawn lines disappear in the same way they  appear. With the paint effect I do not think I can do ...
    any suggestions?
  • Sat, Oct 28 2017 7:58 AM In reply to
    • Tiger_XP
    • Joined on Fri, Feb 2 2007
    • California
    • Posts 462
    • Points 5,095
    Re: SCRIBBLE Animation
        I looked at the entire Bruno Mars video. If the above is all you are going to do then it is possible. I don't use MC for things like this but tried #1 in "Marquee". Marquee is a built in titling tool in MC. Using the text tool I selected the minus sign (-) to create those white lines. #2 was done in Shake. It was eaiser to manipulate the white lines (not minus signs) than in Marquee. Long story short, there is at least one way to get "that" look in MC. As for as the other things done in that video, you will become a Marquee expert by the time you pull it off! Geeked
    1. Done in MC with Marquee
    2. Done in Shake.
    MacPro 2008 3.1 | 34GB Ram | Quadro 4000 980ti 960| MC 8.10 | OS 10.6.8 10.13.6 | MOTU HDX-SDI | ATTO R644| LaCie 324 [view my complete system specs]
  • Mon, Oct 30 2017 3:06 PM In reply to
    • Avidator
    • Posts 19
    • Points 225
    do you mean shake by Apple? I tried with Marquee but the lines are short and I do not have the ability to draw curves ... Other ideas?
  • Mon, Oct 30 2017 7:18 PM In reply to
    You can almost do it with the paint effect.
    1. After drawing the lines, select them with the arrow tool (SHIFT+click to select multiple lines at the same time).
    2. In effects mode select the first keyframe.
    3. Set the path parameter to 0.
    4. Select the last keyframe.
    5. Set the path parameter to 100.
    The lines should now draw on over the duration of the effect. To get them to draw off:
    6. Create a custom shape with the mode drop-down set to erase. The shape should be "behind" the start point of the shapes you drew in step 1. For example, if the lines are moving left to right and you want them to disappear from left to right, draw your erase shape to the left of the lines.
    7. Add a keyframe about halfway through the effect.
    8. Select the last keyframe.
    9. Adjust the size of the shape until it covers the lines, erasing them completely.
    Now the lines should draw on as they did before, and starting at the keyframe you added in step 7 they should draw off in a similar manner. If you feather the edges of the shape you drew in step 7, and if the effect is fast enough, you may not notice that this is a bit of a clunky way to accomplish the effect.
    I hope that helps.
    Media Composer 2019.7 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Mon, Oct 30 2017 7:24 PM In reply to
    This is ugly, but it shows the resulting effect.
    https://youtu.be/zi878vJzWKw
  • Tue, Oct 31 2017 5:25 PM In reply to
    • Tiger_XP
    • California
    • Posts 462
    • Points 5,095
    Avidator:
    Hi, do you mean shake by Apple?
    Yep. Or as most of us like to say, Shake by Nothing's Real. No time to speak of what Apple did to it! Super Angry
  • Wed, Nov 1 2017 9:28 AM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 530
    • Points 6,785
    Hey this is a different editor but you may be able to pull some info that may help you achieve this in MC. The tutorial does use the title tool.
    https://www.youtube.com/watch?v=QuGUuKUlV_k&t=421s
  • Wed, Nov 1 2017 11:58 AM In reply to
    • Tiger_XP
    • California
    • Posts 462
    • Points 5,095
    Based on what I went through in trying this in Marquee he may not return! Yea I know it's for titles but he was getting nowhere with it in MC.
    I became a Blues singer trying it in Marquee! Smile
    Much easier to make shapes in Shake.
  • Wed, Nov 1 2017 7:16 PM In reply to
    • Avidator
    • Posts 19
    • Points 225
    dew:
    Yeah I've seen that tutorial and with Premiere it's very easy...
  • Wed, Nov 1 2017 7:22 PM In reply to
    • Avidator
    • Posts 19
    • Points 225
    camoscato:
    I hope that helps.
    Perfect as always!! It's true is not easy to get a good result but i think is the only way to get this effect with MC. Thanx
  • Wed, Nov 1 2017 7:57 PM In reply to
    You're welcome! Glad to help!
