Latest post Fri, Oct 27 2017 4:01 PM by Erik. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Oct 27 2017 1:44 PM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 69
    • Points 680
    Importing AMT clip in MC 8.8.4
    Hi to all
    I can't import an AMT clip in MC8.8.4.  When I link the aaf, metadata are ok and I see all in the bin, but when I double click in order to display  in source monitor, result is in "media offline".  In previous versions of mc I copied the *.mxf files in the MediaFiles directory.  Now this directory isn't in the root of main volume (c: in my case).  Where I should copy these files ?
    regards
    Filed under: ,
  • Fri, Oct 27 2017 4:01 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 214
    • Points 2,525
    Re: Importing AMT clip in MC 8.8.4
    Avid will look for a folder called Avid MediaFiles on any drive you have connected to the system to look for media.
    If you have MXF media and a drive that doesn't have an Avid MediaFiles folder, you can just create one in the root of the drive. Then make a subfolder called MXF and then a sub folder contained in there called 1
    The folder structure will look like this:
    [drive] Avid MediaFiles > MXF > 1
    copy your MXF files into the 1 folder.
    Start up Avid and it will find the Avid MediaFiles folder and begin indexing the media.
    MC 2019.9 Asus Prime X299 Deluxe, 64GB of Memory, Core i9 7940x @3.1Ghz, Nvidia GeForce GTX 1070 Ti. Running Win10 Pro 64bit MC 2018.4 Dell Precision... [view my complete system specs]
