Latest post Thu, Oct 11 2018 1:11 PM by charlie_s. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Oct 14 2017 4:03 PM
    • johan
    • Joined on Fri, Dec 28 2012
    • dubai
    • Posts 94
    • Points 1,000
    Avid airspeed 5500 TOD timecode
    what is this alert mean ?
    HP z400,z420,z620,z640 , windows 7 pro 64 bit , avid isis 5000 , avid airspeed 5000/5500 , avid newscutter 10, avid inews server , avid command news server... [view my complete system specs]
  • Sat, Oct 14 2017 5:51 PM In reply to
    Re: Avid airspeed 5500 TOD timecode
    That you Time Of Day has changed or is out of sync with incomming LTC.
    These airspeeds are hyper sensitive with LTC signal issues and depending or your time distribution scheme the amount LTC and the pc's clock can drift which leads to all kinds of weird warnings and errors
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
  • Mon, Oct 16 2017 7:21 AM In reply to
    • johan
    • dubai
    • Posts 94
    • Points 1,000
    Thank you for your info , but it is a strange thing that the server time is synced with domain controller time ! is it recommanded to create NTP server instead from sync with server time ?
  • Sun, Oct 22 2017 11:07 AM In reply to
    I would first check the airspeed is correctly reading the incoming ltc.
    A simple test I do is to hook up a small audio mixer to hear the ltc timecode and to be able to meassure and change the audio level. It would not be the first to time a LTC (audio) distribution amplifier is not connected correctly or is not handling symmetric/asymmtric levels corectly.
    I also download an adroid ltc generator on my android phone
    https://play.google.com/store/apps/details?id=com.AaronBernstein.ltctimecodegenerator&hl=en
    and hook it up to the same mixer through the minijack headphone output. (I have also used android emulators for Pc but a phone is more practical for a temporary testing setup.)
    Now check the behavior of the airspeed while changing levels and ltc source.
  • Thu, Oct 11 2018 12:35 PM In reply to
    Hi again,
    To get back on this issue. On a site without LTC clock and adrienne cards we also see this warning without it making sense.
    I'm checking if the lack of LTC in general is considered a warning state resulting in this warning or if something else is going on.
  • Thu, Oct 11 2018 1:11 PM In reply to
    • charlie_s
    • Joined on Tue, Aug 1 2017
    • Posts 18
    • Points 235
    • Avid Developer Moderator
      Avid Employee
    Yes you are correct. The warning is to let you know that there is no LTC connected, and the timecode is coming from the Windows' system time.
