Latest post Fri, Mar 30 2018 6:32 PM by Marianna. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Oct 6 2017 12:21 AM
    • raucsavage
    • Joined on Fri, Oct 6 2017
    • Posts 2
    • Points 30
    New problem with Script Sync 2.0
    I've been using Script Sync 2.0 on a big reality TV show for 4 months now with no issues. I've managed to successfully sync over 20 transcriptions, some over 2.5 hours long. But now all of a sudden when I try to sync my latest two transcriptions it will freeze during the syncing process at the very last second. I'm not able to abort, and I have to force quit avid. I've tried starting a new project, changing the sync settings nothing has worked so far.
    Has anyone else had this issue or know of a fix? Is there a cache that I need to clear out and is the indexing data stored somewhere? Maybe that folder is full, but I'm not sure where it would be located.
    I'm using MC 8.8.5 on a mac mini (OSX 10.10.5) (we only use this machine for script sync and then use our other macs for editing.)
    Any help would be great, thank you.
  • Fri, Oct 6 2017 1:20 AM In reply to
    Re: New problem with Script Sync 2.0
    raucsavage I have moved your post from the MC | First forum to the MC Mac Forum so it will be more visible to people using similar setups.
  • Fri, Oct 6 2017 3:18 PM In reply to
    • Posts 10,666
    • Points 223,900
    raucsavage
    Let me take a look at this and see if we can reproduce it
  • Thu, Feb 22 2018 5:47 PM In reply to
    • yowoody
    • Joined on Mon, May 2 2011
    • Posts 1
    • Points 15
    I am having thesame problem, but only with certain scripts. Have yiu come up with any solutions?
  • Fri, Feb 23 2018 5:43 PM In reply to
    • Posts 10,666
    • Points 223,900
    Have you guys tried......   deleting the file called _SearchDB_  ?   This file is the database of the indexed bins within your project.
    If you have ScriptSync activated, you will also see a folder called PhoneticData which contains a number of files with a .pat extension; these files contain the phonetic information for each of the audio clips within your project.  One .pat file will be created per clip.
    I dont think this is the issue ( .pat file ) but it might be worth deleting the SearchDB and then restarting and rebuild it.
  • Fri, Mar 30 2018 6:25 PM In reply to
    • Aren Hansen
    • Joined on Tue, Mar 15 2016
    • Toronto
    • Posts 56
    • Points 620
    I don't see these .pat files or the PhoneticData on my mac. Are they saved with the project?
    2018.12.7 // OS10.14.5 // iMac 2019 3.6 i9 // 72GB Ram // Vega 48 // [view my complete system specs]
  • Fri, Mar 30 2018 6:32 PM In reply to
    • Posts 10,666
    • Points 223,900
    Aren
    Listed below are the Q/A that shoud help.
    Q:There are folders and files in my Project folder I didn’t create. What are they and what do they do?
    A: In each Project folder, you will see a folder called SearchData which contains a file called _SearchDB_. This file is the database of the indexed bins within your project. If you have ScriptSync activated, you will also see a folder called PhoneticData which contains a number of files with a .pat extension; these files contain the phonetic information for each of the audio clips within your project. One .pat file will be created per clip.
    Q: Is there a file count limit to the PhoneticData folder?
    A: Yes, the PhoneticData folder works like the AvidMediaFiles folder; once the first folder reaches 5,000, it will create another folder with a 2 appended to the name and continue to create new folders as the previous folder gets full.
    Q: Do ScriptSync and PhraseFind share the same .pat files?
    A: No, they are different files, but the files are small enough that this will not adversely affect either performance or storage requirements for most projects.
    Q: How do I activate my ScriptSync license?
    A: ScriptSync 2.0 uses the Avid Application Manager to manage activations and deactivations of its license. For more information on using Application Manager, please refer to the Media Composer Installation Guide
