Latest post Fri, Feb 2 2018 3:43 PM by Marianna. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Tue, Sep 26 2017 7:50 PM
    ** HIGH SIERRA: Download, but DON'T INSTALL **
    On September 26th, Apple released macOS High Sierra (10.13.0). At this time, it is not supported by Avid and should not be installed on any Avid workstation.
    HOWEVER, once Apple releases 10.13.1, the base version of High Sierra will no longer be available. It is HIGHLY RECOMMENDED that all Avid users who intend to upgrade at some point download High Sierra from the App Store, but don't install it. There will be an file in your Application folder called "Install High Sierra" which you can keep until needed.
    When Avid does qualify High Sierra, you are able to install the base version, then download whatever "Combo" updater required that will get you to an approved OS. But if 10.13.1 is released the day Avid qualifies 10.13.0, you won't be able to get the base version unless you've already downloaded it.
    So, as I always recommend when new OSes come out, DOWNLOAD...BUT DON'T INSTALL (yet).
  • Wed, Oct 11 2017 3:25 AM In reply to
    • Tiger_XP
    • Joined on Fri, Feb 2 2007
    • California
    • Posts 462
    • Points 5,095
    Re: ** HIGH SIERRA: Download, but DON'T INSTALL **
    Kevin Klimek:
    When new OSes come out! If you have been on Macintosh for years you know there have been a train load of them! Big Smile
    (not JPluta or affiliated with this person. Used the train photo to play with (non profit) but did not want to delete his/her name Yes)
    MacPro 2008 3.1 | 34GB Ram | Quadro 4000 980ti 960| MC 8.10 | OS 10.6.8 10.13.6 | MOTU HDX-SDI | ATTO R644| LaCie 324 [view my complete system specs]
  • Fri, Oct 13 2017 11:31 PM In reply to
    • Zach Fine
    • Joined on Thu, Mar 31 2011
    • Posts 37
    • Points 435
    Is Apple really starting to do that for macOS, as opposed to iOS? --as far as I can tell all of Apple's OS installers going back many versions, years and years, are available on their servers over here: https://support.apple.com/downloads/macos
    Before getting tired of hitting the 'Load more results' button I saw downloads links for many versions (likely all) of Sierra, El Capitan, Yosemite, and Mountain Lion on that page. Didn't check for completeness. There's a similar but maybe more extensive list of downloads available in apple's developer pages, accessible with a free developer account.
    Because I wanted to try out the new OS's features, I've gone ahead and installed macOS High Sierra (Version 10.13) on an external thunderbolt SSD drive and am currently booted from it. Media Composer 8.8.2 seems to be working fine so far for me, with Blackmagic a/v output. It may not yet be a supported configuration, but I've run into no issues yet.
    Media Composer 2018.4.0 OS X 10.13.3 Late 2013 MacPro 3GHz 8-Core 128Gb RAM D700 GPU [view my complete system specs]
  • Sat, Oct 14 2017 1:16 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,506
    • Points 42,240
    Zach Fine:
    Well, I went to the suggested link and stopped looking when I could NOT fine the base install of Sierra - 10.12.0 - updates yes, base no.  Did I miss it?
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." mostly 8.11.0 but playing w 2018.12.6|OS 10.14.x - iMac 2017 - home system MacPro Dual 2.8 8core... [view my complete system specs]
    Jef Huey
  • Sat, Oct 14 2017 3:42 AM In reply to
    • Zach Fine
    • Posts 37
    • Points 435
    Nah you didn't, I just looked and didn't see it either.
    Looks like you're right! Argh, that sucks. In the developer section Apple does make all versions available of every OS but with debugging symbols, and that may or may not affect performance to use as an OS.
    The comments after this article mention a couple of alternate ways to download OS X Sierra from official Apple sources (no way to specify a particular version). Of course one can fairly easily find the base level version of Sierra on google drive or via torrent, but then you're trusting an unofficial source and could potentially end up with security issues.
    https://www.macrumors.com/2017/09/26/macos-sierra-decoupled-from-apple-id/
  • Mon, Oct 16 2017 8:29 AM In reply to
    • Susi
    • London, UK
    • Posts 578
    • Points 6,655
    OK here's a really stupid question; thought I'd downloaded High Sierra, but nothing shows in 'downloads' folder. Only result seems to be the floating window inviting me to continue with installation.
    What to do?
    (Early stages of specc'ing a new laptop)
    Media Composer 8.6.4 on 15" mid-2012 Macbook Pro (OSX10.11.6) 2.7GHz Intel, 8GB RAM Gizmos: CanonXF200; Canon 550D (DSLR); Hero Go-Pro3 and 4; Sony... [view my complete system specs]
  • Mon, Oct 16 2017 9:23 AM In reply to
    Quit the installer - it'll sit there in your Applications folder ready to be used when you need it.
  • Mon, Oct 16 2017 11:11 AM In reply to
    • Susi
    • London, UK
    • Posts 578
    • Points 6,655
    Thank you so, so much!
  • Sun, Oct 22 2017 8:47 PM In reply to
    • Zach Fine
    • Posts 37
    • Points 435
    Here's an addendum on the idea that it's "working fine" in High Sierra -- of course there'd be a quirk somewhere. On playback through a Blackmagic Decklink Extreme 4k with their latest driver, audio and video over the SDI out are out of sync. Exports are in sync, it's just likely something to do with the driver interaction and something that's exactly the sort of reason to wait for an Avid-approved version before upgrading your OS.
  • Mon, Oct 23 2017 1:56 PM In reply to
    • Dale Gagne
    • Joined on Mon, Oct 24 2011
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    Also keep in mind that Apple now puts expiries on thieir installers. After a number of weeks that installer will not open or work. If you make a boot disk out of it onto a usb if you really need to keep it for future use.
    Avid MC 2018.12.3, Avid Mojo DX, Mac Pro, Mid 2012, 2x2.4 ghz 6 CORE Intel Xeon, 64GB Ram, SSD Startup, 10.14.0, Radeon RX 580 8g, 9TB Internal Storage... [view my complete system specs]
  • Tue, Oct 24 2017 7:53 AM In reply to
    Once you've downloaded High Sierra and then stopped installation (e.g. by not accepting the contract), it should be available for installation "forever" within the AppStore software.
    I needed to reinstall Yosemite a few weeks ago on an old machine but teh .dmg I'd downloaded and moved to an archive drive was defective (probably the expiry date, as Dale noted above) and the "install" button in the AppStore was greyed out. I cursed Apple for a bit, then I called their hotline. After explaining why on earth I wanted Yosemite (Adobe CS5.5), the Apple person helped me solve the AppStore problem and Yosemite was installed.
    The important thing as Kevin says, is to record a "purchase" of the OS in the AppStore.
    Edit 1: MC 8.10 + Symphony + PhraseFind • MacPro 6x3.5GHz/64GB OS10.10.5 • Artist Mix & Color • Aja Io 4K • Edit 2: MC 8.10 • MacPro 2x2.66GHz/48GB... [view my complete system specs]
    Rodney Sewell BFS
  • Mon, Oct 30 2017 2:14 PM In reply to
    Dale Gagne:
    I have gotten around that in the past by changing the system date/time to make sure it is close to the release of the original file. Haven't tried that past El Capitan, but it works for those releases.
  • Mon, Oct 30 2017 11:21 PM In reply to
    • Dennis
    • Joined on Mon, Jul 6 2009
    • Posts 76
    • Points 850
      Avid Certified User
    From the "Read Me" file for ver 8.9.3 that was released today:
    "This release includes support for Mac OS v10.13"
    MacBook Pro Retina 16 gig ram, Mac Pro 12 core, 16 gig Ram. [view my complete system specs]
  • Tue, Oct 31 2017 11:22 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,219
    • Points 14,740
    Yeah!
    Now is it worth upgrading to High Sierra is another debate... Thanks Avid for qualifying it pretty fast!
  • Tue, Oct 31 2017 12:25 PM In reply to
    • Posts 10,676
    • Points 224,050
    Pierreh
    I'll let the hard working QA and test teams know you said thanks!
