Latest post Thu, Sep 14 2017 1:48 PM by jakeheat. 7 replies.
  • Tue, Sep 12 2017 12:53 AM
    • cesaromar
    • Joined on Fri, Mar 23 2012
    • Posts 40
    • Points 480
    Consolidate crashes Avid
    Having trouble consolidating media. Avid crashed at different points of each reel when I try to consolidate to an external drive. It is a problem with the audio, as I consolidated just the video and it works fine like that. Also tried exporting an AAF and it crashes as well.
    I'm working off of a ISIS backup on a RAID.
    MacBook Pro (15-inch, Early 2011), OS X Yosemite 10.10.5, 2.2 GHz Intel Core i7, 16 GB RAM [view my complete system specs]
  • Tue, Sep 12 2017 1:37 AM In reply to
    Re: Consolidate crashes Avid
    What format is your audio?
    Can you consolidate audio only?
    cesaromar:
    An Audio only AAF?
  • Tue, Sep 12 2017 1:48 AM In reply to
    • cesaromar
    • Posts 40
    • Points 480
    All of the audio has been imported, so it's MXF media.
    No, I cannot consolidate audio only. But I can consolidate video only.
    I also cannot export an audio only AAF.
  • Tue, Sep 12 2017 2:14 AM In reply to
    In your Audio Projects Settings is Wave (OMF), AIFF-C(OMF), or PCM (MXF) selected?
    Is this is for backup purposes? If so as Audio Files are relatively small would it work for you to Batch Re-import the original files to your external disk?
  • Tue, Sep 12 2017 3:13 AM In reply to
    • cesaromar
    • Posts 40
    • Points 480
    PCM (MXF)
    We are currently making changes to a project that used to live on an ISIS. This would not be for backup purposes.
  • Tue, Sep 12 2017 9:54 PM In reply to
    • cesaromar
    • Posts 40
    • Points 480
    I get this message in the Console window:
    p, li { white-space: pre-wrap; }
    MTSC state = 0The single frame player will be built for a length of 3600 frames
    MSMRescan() took: 2.232529s
    Set persistent image cache limit: 200.0 MB in /Users/Shared/AvidMediaComposer/AvidImageCache
    WARNING: Requested LocateBuffer size 2048MB is the same as current size 2048MB.
  • Tue, Sep 12 2017 11:12 PM In reply to
    • cesaromar
    • Posts 40
    • Points 480
    This is the message from Apple's crash report:
    Application Specific Information:
    abort() called
    terminating with uncaught exception of type XError: MXFDomain::SaveMetaDataToFile - Failed to save meta data to file
  • Thu, Sep 14 2017 1:48 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 503
    • Points 6,075
    Couple of suggestions.
    - Have you tried exporting a singe audio file - or are you exporting everthing together. It maybe one corrupted clip.
    - Try transcodeing the clip to your selected drive instead.
    - Check there's no permission issues with the Raid drive - test a consolidate to another drive.
    - import an audio file and export it to check if its to do with your software of the way your source material was encoded.
    Good luck
    Media Composer 2019.8.0 Dell Precision 5820, 32GB, i9-9920x, Quadro P2000, W10 [view my complete system specs]
    @jaketheeditor
