Latest post Mon, Aug 21 2017 1:25 AM by TVJohn. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Aug 17 2017 3:59 PM
    • Jonas Cox
    • Joined on Fri, Jan 9 2015
    • Springfield, MA
    • Posts 23
    • Points 275
    "Select In/Out" is inaccessible in Command Palette
    I'm trying to map the Select In/Out function/button to my keyboard. I've tried clicking and have had no luck "grabbing" the button so that I can pull it down and release it onto my keyboard. It seems to owe to the fact that the Select In/Out button is overlain by the text of the button to the right of it (Segment Mode (Extract/Splice-in)). I've attached a grab showing what I mean.  Is anyone else having this issue?
    I'm running Media Composer 8.9 on Windows 7 Professional.
    TIA,
    Jonas
    MC 8.9 on Dell 7910 (Windows 7 Professional),with Nitris DX and ISIS [view my complete system specs]
  • Thu, Aug 17 2017 7:27 PM In reply to
    Re: "Select In/Out" is inaccessible in Command Palette
    I just tried this on MC 8.9 and Win 10 and it workes as expected. My command palette is wide enough to display all the commands properly, too. I don't know if it matters, but my screen resolution is set to 1920x1080.
  • Thu, Aug 17 2017 8:05 PM In reply to
    I just tried mapping Select In to out  to my KB on MC 8.9 and Win 7 Pro 64 SP 1 and it workes as expected.  I do not see any overlapping text with my Command Pallete  (using dual 22 inch 1680 screens)
    Hi
    Jonas.
    Can you try a new user profile?
    CJ
    AVID MEDIA COMPOSER 5.5.3. PC. WINDOWS 7, SP1. 64BIT OPERATING SYSTEM. QUICK TIME VERSION 7.6.9. [view my complete system specs]
    Christian Jhonson
    Avid Ambassador
    christianjhonsoon@hotmail.com
  • Thu, Aug 17 2017 8:34 PM In reply to
    • Jonas Cox
    • Springfield, MA
    • Posts 23
    • Points 275
    Thanks, guys.  My max resolution on my monitors is 1680x1050, so that might be the problem.
    And Christian, I encountered this as I was building a new user profile; also, I just checked on a different user profile, and same issue.
  • Thu, Aug 17 2017 8:37 PM In reply to
    • Jonas Cox
    • Springfield, MA
    • Posts 23
    • Points 275
    Andrew, your setup sounds identical to mine, so I just want to be sure:  I'm talking about the button that, based on your in and out points, will select all clips within that region so you can move them via segment mode.  I'm not talking about the Mark Clip function (which one could almost as easily call Select In/Out); that button is accessible for me.
  • Thu, Aug 17 2017 10:19 PM In reply to
    Jonas Cox:
    It is the one you are talking about. See  attached.
  • Fri, Aug 18 2017 5:01 PM In reply to
    • Jonas Cox
    • Springfield, MA
    • Posts 23
    • Points 275
    Ah, if only I could grab it from your *picture* and map it on my keyboard  Smile
  • Fri, Aug 18 2017 10:02 PM In reply to
    Have you tried Christians suggestion in this thread to create a new user?
    With this new user open the Command Palette and see if your text is still overlapping.
    If the text is not overlapping you will be back in business.
    If the is still overlapping there is something wrong with the graphics card driver / Displays setup.
  • Sat, Aug 19 2017 8:40 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,712
    • Points 66,980
    Jonas Cox:
    TIA,
    Jonas
    I guess the issue is the labels overlapping the buttons, therefore MC not properly scaling the GUI as per Your monitor resolution; MC 8.9 should somehow fix this, search the forums for workarounds, did not double check but going by memory the relevant thread should be http://community.avid.com/forums/t/179810.aspx.
    Symphony 20.06, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Mon, Aug 21 2017 1:25 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,368
    • Points 53,960
    Are you using the recommended NVidia driver?
    Using MC 20.6. Avid FX6.4, Vegas Pro 17/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
