Latest post Thu, Sep 28 2017 8:27 AM by BenoitM. 3 replies.
  • Sat, Aug 12 2017 4:38 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,086
    • Points 13,155
    How do pro editors usually deal with 30p phone footage in PAL world ?
    When including footage from a phone (usually 30p) in a project in the PAL side of the world (25p or 25i) - and this is becoming more and more common I reckon, in certain types of projects at least-, I found that the default motion adapter (120%) results in irregular pan or other movement rendering (brute force frame skipping), while fluidmotion requires sometimes astronomic render times and often manual fine tuning of vectors (depending on scene content).
    So I wonder how pro editors deal with this ? Or is it so that in some cases (broadcast), hardware framerate conversion tools are used instead ? Just curious...
    MC 2018.1 (Symphony option)/BCC 10.0.5/RED 5.6; Matrox MXO2 Mini (8.0.0); DELL Precision M4700 - Intel Core i7-3740QM 2.7 GHz - 24 GB RAM; nVidia Quadro... [view my complete system specs]
  • Sat, Aug 12 2017 11:09 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 98
    • Points 1,040
    Re: How do pro editors usually deal with 30p phone footage in PAL world ?
    I mostly use phone footage at 25fps in a 25 fps project and accept the slight slow mo.
    iMac Retina27 late 2017 4.5Gz i7 40GB AMD 8GB with Sata Raid OS 10.13 MC 8.9.4 BMD mini monitor with Eizo monitor [view my complete system specs]
  • Sun, Aug 13 2017 4:11 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,331
    • Points 96,315
    The jumps are more likely to be due to the variable frame rate that the phone captures at.  Depending on how eratic the frame rate is there may be no practical way to get rid of that problem.  However when I've had to do this in the past I've set up a batch job using slowmoVideo on a spare PC.  Alternatively, if it's only a few I've used AE to change the speed.  Haven't had to do it recently though.
    I also recall once importing 30 fps media into an AE project and exporting it as 24, then dealing with the 24 fps media as 25 with a fair degree of success.  In that case we had to integrate a bunch of establishers shot at 30 fps in LA into a local 25 fps project.  I don't recall the full details, I just know that we got it to work, but that it was a pain to do.  Because there was no sync to worry about, in the end it worked really well.
    Of course all the above totally ignores the sound.  That's a whole new ballgame.
  • Thu, Sep 28 2017 8:27 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,086
    • Points 13,155
    Experimenting a bit more and because most 'brute force' 120% MA visual problems occur during camera panning, I found that applying a stabilizer ("smooth") effect (on top of the 120% MA with "Duplicated Field") yields better results; depending on the scene content (rolling shutter jello effect and/or rotational shake), either the BCC or the MC stabilizer gives better control or results. The MC filter will add field interpolation if it's a 50i project, which adds nice smoothness when there is panning while the BCC filter does a better job in sharpness control or when there is rotational shake.
    Also, setting the MA to "both fields" (in: progressive, out:interlaced) gives very slightly better results
    So for me, when using 30p phone footage in a 50i project and speed may not be changed for some reason, the best way to go is to:
    1) apply a 120% MA (default) with "both fields"
    2) add a stabilize effect (MC or BCC) with short-range smoothing value (e.g. 10 frames)
    In case this would help someone....
