Latest post Mon, Aug 14 2017 3:11 PM by AsafBlasberg. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Aug 10 2017 9:31 PM
    Avid Locks Up My Machine
    Hello,
    Avid locks up my machine for a few seconds when I scrub through the timeline.  This is the first time I've ever seen this issue. Turning off fast scrub solves it, but I wonder what is the cause?
    Thanks folks.
  • Sat, Aug 12 2017 9:57 AM In reply to
    • Marty McLean
    • Joined on Tue, Aug 16 2016
    • Sydney, NSW, Australia
    • Posts 42
    • Points 430
    Re: Avid Locks Up My Machine
    Well knowing your system specs might help.
    2014 MacBook Pro with macOS 10.14.2 | Avid 2018.12 with PhraseFind + ScriptSync | 2.5GHz i7 | 16GB | 2GB GT 750M [view my complete system specs]
  • Sat, Aug 12 2017 3:00 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,334
    • Points 40,335
    Fast Scrub has been evil for many versions.  It just does not get fixed.  It is the first thing I disable when making a new user setting.
    Jef
    Jef Huey
  • Sun, Aug 13 2017 11:53 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,610
    • Points 60,250
    I've never noticed this, Jef. Where is that setting?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.11 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64 |... [view my complete system specs]
    Steve
    www.nelliedogstudios.com
  • Sun, Aug 13 2017 8:52 PM In reply to
    • Peter Arnold
    • Joined on Wed, Apr 14 2010
    • Switzerland
    • Posts 36
    • Points 450
    I never had a problem with fast scrub yet.
    But I had a similar problem once, which was even worse.
    As soon as I opened another window i.e explorer or even the title tool avid would freeze immediately.
    The solution was a clean install of the nvidia driver. Not just an installation of the newest version but a clean install. If you install the new driver there is a box that can be clicked that says something like 'complete install' or 'clean install'
    Don't know exactly how it's called in english because I'm on a swiss german speaking computer.
    Anyway, what it does is it will first delete every single piece of nvidia drivers and software lurking around from previous installs and will then do a complete new install of the driver.
    It helped in my case and the system is running without a single hickup since.
    Hope that helps
    Peter
    HP Z820 | 2x Hexa-Core Xeon E5-2640 2.5GHz | 32 GB RAM | Quadro K4000 | Win7 Pro SP1 | MC 2012.12.1 | QT 7.7.9 | Nvidia 390.77 | RED Rocket... [view my complete system specs]
    "I've seen things you people wouldn't believe"
  • Mon, Aug 14 2017 2:58 PM In reply to
    • Posts 10,079
    • Points 216,475
    Jef
    which exactly spec of the system vcan you make this happen on?
  • Mon, Aug 14 2017 3:11 PM In reply to
    Hi all,
    It turns out my issue was not Avid-related.  It was related to my USB hub locking up my machine.
    So sorry :(
