Latest post Mon, Aug 14 2017 2:29 PM by Jeroen van Eekeres. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Aug 7 2017 6:49 PM
    • johan
    • Joined on Fri, Dec 28 2012
    • dubai
    • Posts 81
    • Points 835
    upgrade Avid interplay server from 3.4.0 to 3.8
    Dears i need your help,
    I'm planning to update interplay server from version 3.4.0 to 3.8 , is it possible or should i go through another lower version ?
    the upgrade procedure is it just uninstall the old versions then restart and install the new one ?
    Thank you very much.
    HP z400,z420,z620,z640 , windows 7 pro 64 bit , avid isis 5000 , avid airspeed 5000/5500 , avid newscutter 10, avid inews server , avid command news server... [view my complete system specs]
  • Mon, Aug 14 2017 2:29 PM In reply to
    Re: upgrade Avid interplay server from 3.4.0 to 3.8
    Normally the Interplay installer will take care of the required uninstall. A manual uninstall through the control panel is not needed. Avid advices against it actually.
    A 3.4.0 to 3.8.0 is a direct install on top path. Make sure you do a full backup of your database first so you are able to go back to the original situation if something goes wrong.
    Avid reseller ACSR at Telmaco
