Latest post Thu, Aug 31 2017 5:07 PM by Jeroen van Eekeres. 29 replies.
Page 2 of 2 (30 items) < Previous 1 2
  • Sat, Aug 5 2017 8:47 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 157
    • Points 1,990
    Re: Media Composer v8.9 - Launched
    curiosity:
    Heads up! The MC 8.9 installer downgrades your Application Manager to 17.5.1 This is a little annoying since 17.7 has some fixes for CPU high useage.
    I just submitted a support ticket for high cpu usage of Application Manager v17.5.1 and the response I got from support wasn't "we are aware and have a new version that fixes that." No, the response was "there must be something wrong with your computer because the application manager doesn't have a high cpu usage."
    Thank you Curiosity and yet another "gold star" for the "wonderful"  support team at Avid.
    Charles
    HP zBook 17 G3, z220, HP z240, HP z420, HP z440, HP z840, HP Z4 G4, Dell Precision 3430, Dell Precision 7810, Apple iMac i5 27-Inch (5K, Late 2015). 16GB... [view my complete system specs]
  • Sun, Aug 6 2017 9:12 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,669
    • Points 66,515
    Jeroen van Eekeres:
    Adman:
    - Occasionally, when working with media with effects or media where space, time or color adapters were rendered during transcode or video mixdown, you might see artifacts during playback or export. *** Workaround: Go to the Render Settings dialog and choose Disable GPU effects.
    No, this can't be true. Not again.
    I wonder what is the point in purchasing those expensive Quadro cards if You have to disable GPU effects...
    Did not take a test drive, but by reading the what's new I'd say that the audio slip is clunky; it is, more or less, the old perf slip ported to non film projects, only useful for autosync and (perhaps) grouping. Will true subframe audio editing arrive some day?
    Support for HiRes monitor it's not clear to me, is it true support, or just blowing up the low res to fit hi res?
    Symphony 20.04, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Sun, Aug 6 2017 8:26 PM In reply to
    I have no idea. I guess since you update your MC dongle through the application manager and since several other Avid products recently also started using the application manager, Avid does not believe it's needed anymore.
    But to be sure we would have to ask Avid.
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
  • Sun, Aug 6 2017 11:07 PM In reply to
    Jeroen van Eekeres:
    That would IMO be an exceedingly bad belief to hold. Why do I hold this opinion?
    1: The Dongle manager has not been broken in nearly 30 years. (Have Avid rewritten the Dongle manager more than a couple of times in all those years.)
    2: Here the Dongle Manager has saved me more than once when the Application Manager cause issues.
    3: Maybe my Memory is not as good as it used to be but I cannot remember one of the dozens of versions of the Application Manager over the last 3 (?) years that has not broken something.
    4: The Application Manager unneccesarily uses far to many system resouces. The App manager regularly has cache issues     requiring me to waste quality editing time researching and fixing APP Manager issues.
    5: I do not want to spend hours fixing Application Manager induced dongle issues. It seems like I could probably retire with if I just had a dollar for every hour Avid Support spent fixing Application manager issues.  Sad
  • Mon, Aug 7 2017 9:48 AM In reply to
    Andrew,
    (from my personal account)
    The Application manager and Avid master account were (and could still be) always going to cause problems as Avid never took the decision to 'clean up' or 'consolidate' the underlying databases and information stored in them. Until today, if you create a new master account you still need to create a separate account for the download center, one for the community, web store billing information and an iLok account depending on your personal setup. (And add to that a partnercentral and ACA account for guys like me)
    If you order a big system with multiple edits, Interplay, airspeeds with codec boards, iNews, media central you still get a big envelope with all kinds of paper work in which each paper contains a system ID and/or activation code. Do I care that the one paper is on yellow thick paper US letter format, the other on yellow thick paper A5 or half size US letter while the other is a white printed A4 and that iNews, iNews command and Interplay capture come with dongles with temporary linceses to create an activation file (like a device ID) for which I need to communicate with support or sales? No, after so many years you get used to the procedures for each product. But the way Avid handles these remnants of their frankenstein portofolio of products (Digidesign, ORAD, Basys, NxN, Pinnacle, Euphonix, Sibelius to name the most important) is a good analogy for the internal structure and the amount of succes or failure.
    Now in 2017 (29 years after Avid was founded) Avid is ditching Avid license control and is implementing the application manager in most Interplay products. Hallelujah! After Protools and Nexis another product joins a single licensing mechanism. A small step for man, a giant step for Avidkind. Does that mean that protools licenses can now be handled by the same people that handle media composer licenses? Of course not... Am I nuts? How dare I suggest that is even an option.
    Now I could continue ranting about a Manilla project and some of the services and support engineers that were fired in the US and EMEA but I do not want to get moderated. The text above is already too much about Avid's internal operations.
    That said. I would be soooooooooooooooo happy if I would see all Avid products a customer has including older existing products which are still in the current Avid product portofolio in ONE single master account.
    Linking SAP, Partnercentral and masteraccounts to one single database... I keep dreaming.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Thu, Aug 10 2017 7:53 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    8.9 works great, nice little things added that really help - love the new mixer look. Wanted to add that the Nitris DX issue seems to have gone away, and MC sees the box just fine now.
    Dell T3600T 12 Cores 3.5 ghz Intel 32GRAM K4200 Windows 10 [view my complete system specs]
  • Sat, Aug 12 2017 5:08 PM In reply to
    • Arthur Klein
    • Santa Monica CA
    • Posts 140
    • Points 1,790
    Yesterday I installed MC_8.9.0_Win_98532 on Win7 Ultimate OS.  It seems to work fine exept that the Avid Background Service Manager icon in the task bar remains RED all the time Avid MC is running... I reverted back to Avid-8.8.5_Win_97980 and problem goes away.
    So when can we expect 8.9.1 rev?
    Seems that smart move is to stick with 8.8.5 for forseeable future.
    Also I am dongle user and IMHO it would seem to me that to kill Dongle Manager is a mistake since it has ALWAYS WORK and is SOLID.
  • Fri, Aug 18 2017 3:45 PM In reply to
    If only I could download the Windows version.
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440/800/820 PC's on W7/10 x64. 3 x Mac, 4 x PT 2019.12 HDX, S6 , X-MON, all on PCs. NEXIS E4 & ISIS 5000 X... [view my complete system specs]
  • Fri, Aug 18 2017 4:12 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,146
    • Points 23,890
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Looks like it's a corrupt download, did you try downloading again?
    RalphC
  • Fri, Aug 18 2017 4:34 PM In reply to
    ....several times.  Even from a different PC.   I downloaded the Mac version and some other files OK.   It's just the PC version which is a problem.
  • Fri, Aug 18 2017 4:49 PM In reply to
    • RalphC
    • Posts 2,146
    • Points 23,890
      Avid Employee
    Can you try this, right click the zip file then "Extract files" change the path to Downloads\Media_Composer_8.9.0_Win
    RalphC
  • Fri, Aug 18 2017 5:29 PM In reply to
    • Posts 11,203
    • Points 231,085
    Report back and let us know if what ralph suggested worked...
  • Fri, Aug 18 2017 6:07 PM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    When you say windows 10 pro is supported, you mean the very first one?  What version number should my About/Version/ say.
    Creators is: 1703
    w10, mc 2020.4, diy x299 7940x [view my complete system specs]
  • Tue, Aug 22 2017 6:02 PM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    I'm getting mixer issues.  Somtimes changing clip volume doesnt do anything (I have to keep moving the slider for it to register)
    And if I hit tab, it doesnt go from one track to another.
    Im still editing my current project with 8.9 but some small things ive noticed.
  • Thu, Aug 31 2017 5:07 PM In reply to
    cls105:
    Hey that's interesting... I just reported the same problem yesterday.
