Latest post Wed, Apr 25 2018 1:40 PM by Dom Q. Silverio. 3 replies.
  • Wed, Jun 28 2017 1:51 PM
    Prores workflow
    Hi all,
    I'm going to be editing with pro res 422 (1920x1080) footage shot from an Alexa. I'm editing with Avid media composer 8.6.5, am i right in thinking that I can just import the .movs into Avid and the .movs will be re-wrapped into MXF? Is this the best way to imgest into Avid?
    If I had the option to edit with DNX .movs would Avid import the DNX.movs faster than pro res .movs?
    Mike
  • Wed, Jun 28 2017 4:01 PM In reply to
    Re: Prores workflow
    Avid MC supports both codecs natively.
    You may want to AMA link to the MOV files and consolidate. AMA linking has more features than traditional import including LUT support.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Mon, Apr 23 2018 8:31 PM In reply to
    • Burk
    • Joined on Thu, Sep 8 2016
    • Posts 5
    • Points 45
    Re: Prores workflow
    Hi Dom and Michael,
    Working with MC 8.9.4 I've been able to successfully consolidate and cut with ProRes422 media from an Amira, and then output that with my usual workflow (Output --> AMA File Export...) wihtout a hitch so far.
    Have either of you experienced problems anywhere in the process with consolidating ProRes QT's vs transcoding them to DNxHD?  In my experience, any time spent transcoding triples ingest time.  I prefer to consoldiate everything (XDCAM, XAVC, etc.).
    Have consolidated ProRes MXF files (created by Avid) proven to be just as stabile as DNxHD provided it's a Mac based edit environment?
    Thanks,  Burk Finley Post Supervisor Lusid Media
    Mac Pro 2013, MC 8.9.4 or later, Resolve 14.3 [view my complete system specs]
  • Wed, Apr 25 2018 1:40 PM In reply to
    Re: Prores workflow
    We have shows that are ProRes from beginning to end using Media Composer.
    The most common issue we have is Avid unable to consolidate some ProRes file. These files often are generated from third-party software that depends on FFMPEG encoders.
