Latest post Tue, Jun 27 2017 9:25 PM by opie177. 3 replies.
  • Tue, Jun 27 2017 7:17 PM
    • opie177
    • Joined on Wed, Nov 18 2009
    • Chicago
    • Posts 72
    • Points 1,010
    Nothing complicated. Just FILLER
    OK... for YEARS and YEARS... since Avid on a Mac when AVR75 was king... I have always pulled the source monitor menu down and been able to load FILLER. I could make marks for the duration I needed. I use this very often. Maybe not the best way to do it... but after all these years you get used to it.
    Today, edit as usual, and pull that menu down and FILLER is GONE! I found it under the timeline menu, and I can add it at the top of the Seq or at position. But I want/need more than 1 second of it. Actually I use it in different lengths for different things.
    To me personally... why not have it where it used to always be? If it wasnt broken, why fix (or move) it?! Help me find FILLER and allow me to determine the length. Boy, I hope there is a way to get it back.
    Avid MC 8.8.4 on HP Z820
    HPZ820, 2.6GHz,32G, Win10, NitrisDX, MC12.6 [view my complete system specs]
  • Tue, Jun 27 2017 7:54 PM In reply to
    • opie177
    • Chicago
    • Posts 72
    • Points 1,010
    Re: Nothing complicated. Just FILLER
    My apologies... I found filler in the composer menu when the source monitor is selected. Why it was moved from the source pull down I wont understand. You know... in the closest spot to where you need it. But, oh well. At least its there somewhere.
    thanks
  • Tue, Jun 27 2017 9:22 PM In reply to
    You can map Load Filler to your KB using the Command Palette (Menu to Button reassignment). And or map it the a button below the Source window if you prefer the option to select with the mouse.
  • Tue, Jun 27 2017 9:25 PM In reply to
    • opie177
    • Chicago
    • Posts 72
    • Points 1,010
    PERFECT! Thank you.
