Latest post Mon, May 8 2017 4:46 PM by jef. 3 replies.
  • Mon, May 8 2017 1:55 PM
    • Eric V
    • Joined on Tue, Jun 23 2015
    • Posts 19
    • Points 215
    DNxHR and alpha in QuickTime
    Is alpha stored with DNxHR in QuickTime done the same way as for DNxHD?
    For DNxHD we expect the alpha to follow the rgb in one QuickTime chunk, and the rgb size to be stored in the last 4 bytes of the chunk. With the DNxHR files exported from MC, I don't see the rgb size in those last 4 bytes...
    Eric
  • Mon, May 8 2017 2:25 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,724
    • Points 44,695
    Re: DNxHR and alpha in QuickTime
    What tool are you using to create the DNxHR w Alpha?
    Jef Huey
  • Mon, May 8 2017 3:00 PM In reply to
    • Eric V
    • Posts 19
    • Points 215
  • Mon, May 8 2017 4:46 PM In reply to
    • jef
    • Maryland
    • Posts 3,724
    • Points 44,695
    As of now, it is not possible to export files with Alpha from Avid.  I believe that feature was shown as "Under Investigation" in a post by Marianna.
    EDIT:  There are some complicated workarounds for this if you are really in a bind.
    Jef
    Jef Huey
