Latest post Wed, Apr 19 2017 6:19 PM by johanV2. 0 replies.
Page 1 of 1 (1 items)
  • Wed, Apr 19 2017 6:19 PM
    • johanV2
    • Joined on Fri, Jan 7 2011
    • Posts 14
    • Points 170
    SOLVED !!! Avid M C 7.02. is crashing when editing a Conceal or LConceal Effect
    Hello,
    When I place the effect Conceal / Lconceal in the timeline and then I edit this effect with the effect editor I get the following message:
    Assertion failed !("WHo\'s calling this?!?!?") File:..\..\src\Consumers\EffectMan\ARealTimeEffect.c, line: 102
    I have allready tested the same effect in another project and also in a testproject and I 've got the same error ! Other effects don't give this error message when editing.
    I have found the same item in this forum without a solution mentionned ....
    I am working with Avid 7.0.2 under Win 7 Prof SP 1 64 bit - IntelCore I7 CPU 920 @2.67 GHZ - Ram 24 GB
    Is ther anyone who can help me ?
    Thanks for yor response !
    Johan
    13/06/2017:  I have received (and with me some other guys I see on this forum) NO SOLUTION for this problem. With the tip of Larry Rubin on this forum about the persmissions I have found that my Avid MC program was reinstalled in a wrong way after my PC was repaired !  The program must be installed with an ADMINISTRATOR account and not with an "account with administrator privileges"   (cfr AMC Guide) !!!!! I have reinstalled AMC with a real ADMINISTRATOR account and now editing effects works fine again !
    Windows 7 Prof 64 bit SP 1 CPU IntelCore I7 920 @ 2,67 GHZ Ram 24 GB [view my complete system specs]
