Latest post Wed, Mar 1 2017 2:23 PM by James Smith. 17 replies.
Page 2 of 2 (18 items) < Previous 1 2
  • Tue, Feb 28 2017 9:54 AM In reply to
    • James Smith
    • Joined on Mon, Aug 8 2011
    • London, UK
    • Posts 14
    • Points 190
    Re: Avid Media Composer to DaVinci re-link imported proxies to original source footage
    Thanks, Andrew. Yes, I think importing proxies is an efficient way of offline editing in my experience. As you say, for the up-res/conform, I'll take the proxies offline and see if I can access the full-res footage for the final stages of this project.
    Avid Media Composer 8.3 running on HP Pavilion G6, Windows 10. [view my complete system specs]
  • Tue, Feb 28 2017 10:58 PM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    James Smith:
    So, in the future, I assume a better workflow (if I wish to work on a low-spec system with proxies) is to trancode all of the footage to the lower-res format, and then go into Avid and AMA link to it? i.e. never use import!
    Actually that is incorrect. The correct workflow is to link and transcode or if Avid recognises the media, link and consolidate. The transcode or consolidate needs to take place inside MC for it to understand where the original source media is.
    John
  • Wed, Mar 1 2017 2:23 PM In reply to
    • James Smith
    • London, UK
    • Posts 14
    • Points 190
    Thanks, Mondo. I'll be taking the advice from everyone on this thread regarding AMA. Also, I'll be doing the grade within AMC/Symphony.
    James
