Latest post Thu, Jan 19 2017 10:50 AM by usatraveler. 2 replies.
  • Thu, Jan 19 2017 12:14 AM
    Can You Upgrade Transcode Quality During Ongoing Edit?
    I'm mid-4K edit and suddenly realised a selection of shots from a given camera were trancoded as DNXHR LB, wheras all the other footage is DNXHR HQ.
    Is there a way to simply upgrade those clips to HQ, thereby automatically replacing the existing lo-res shots in the edit with the correct resolution?
    I'd hate to have to go through the edit individually matching and replacing shots...
    Jon
  • Thu, Jan 19 2017 9:39 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 909
    • Points 11,640
    Re: Can You Upgrade Transcode Quality During Ongoing Edit?
    jon Frontier:
    The only way is to re-transcode from the original source files.
    Joachim
    Joachim Claus
  • Thu, Jan 19 2017 10:50 AM In reply to
    The "relink" dialog is pretty powerful, and will allow you to relink your sequence to higher-resolution transcodes.
    You can transcode the raw shots to HQ.  Then, select the HQ clips in your bin, right-click your sequence, RELINK.. and enable the "Selected items in ALL open bins" option.  This will get your sequence relinked to the clips you've selected - the HQ ones.
