Latest post Fri, Jun 9 2017 8:30 AM by Typhon2007. 48 replies.
Page 3 of 4 (49 items) < Previous 1 2 3 4 Next >
  • Wed, Mar 15 2017 6:13 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    Re: Media Composer 8.7 Render Error/Bug one frame
    Marianna:
    It shoud peace.....
    they are working on it for 8.8.2
    Does that mean it didn't make it into 8.8.1? Well obviously I guess. I really think this is a showstopper and shouldn't be releasing new versions until it's addressed.
    John
  • Wed, Mar 15 2017 6:30 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Mondo:
    Marianna:
    It shoud peace.....
    +1
    Tomas
  • Wed, Mar 15 2017 1:55 PM In reply to
    • Posts 10,516
    • Points 222,135
    Unfortunately not as they havent completely fixed it yet and then there is testing....  8.8.1 is out today so it should be in 8.8.2
  • Thu, Mar 23 2017 2:30 AM In reply to
    • Hoh
    • Joined on Fri, Dec 23 2005
    • Ohio
    • Posts 202
    • Points 2,415
    Yes, I have gotten both the venetian blinds look and a green-tint (and/or magenta-tint) flash frame or series of tinted flash frames.  I'm using XDCAM footage and it seems to happen near transitions.  the venetian blind phenomenon  seems to happen near effects when i'm fading titles/keyed graphics on and off.
    How do I turn off GPU rendering?
    (1): Media Composer 2018.12 ∙ Windows 7 Pro ∙ HP Z840 Xeon E5-2620 v3 2.4GHz ∙ 64GB RAM HP Samsung DDR4 2133 ∙ NVIDIA Quadro K4200 385.69 ∙ Matrox Mojito... [view my complete system specs]
  • Thu, Mar 23 2017 1:51 PM In reply to
    • Posts 10,516
    • Points 222,135
    Hoh
    To remove that GPU rendering button and switch GPU render off .  Render settings, check “Disable GPU effects”
    marianna
  • Thu, Mar 23 2017 1:54 PM In reply to
    • Hoh
    • Ohio
    • Posts 202
    • Points 2,415
    marianna,
    thanks for the quick reply and solid info!
    as always, thanks!!
    -darin
  • Thu, Mar 23 2017 2:32 PM In reply to
    • Posts 10,516
    • Points 222,135
    you got it!  Happy to help!
  • Fri, Mar 24 2017 1:46 PM In reply to
    • Typhon2007
    • Joined on Sat, Sep 4 2010
    • Brussels - Belgium
    • Posts 83
    • Points 1,025
    Hi.
    We just upgrade from MC 8.2 to 8.7.2. It was a lot of work (interplay, archive, transfers, ...). Now we face the same render issue as everybody does.
    Please developpers don'l leave 8.7 without a patch. We cannot upgrade to 8.8 due to interplay version iintegration with third parties.
    Thanks.
    15x z420 - MC 8.7.2 - ISIS 5500 3x64TB - Interplay 3.5 - ProTools 12.6 [view my complete system specs]
  • Fri, Mar 24 2017 3:35 PM In reply to
    • Posts 10,516
    • Points 222,135
    Typhon....
    8.7.x and 8.8.x have the exact same Interplay support.  There is no difference of Interplay support between 8.7.x and 8.8.x
    I’m curious why you think 8.8.x is different from 8.7.x in this regard.
    Can you elaborate?
  • Fri, Mar 24 2017 4:11 PM In reply to
    • Typhon2007
    • Posts 83
    • Points 1,025
    Hi Marianna.
    Thank you for giving me that precision. Indeed in the Interplay production Matrix i see that we can use MC 8.8 on our fresh interplay 3.5.
    We are coming from 8.2.10 where we were stuck because of Inerplay 3.0.5. I had the reflex to link the MC version to Interplay..
    We decided to install an already tested version (8.7.2) instead of using a too fresh 8.8. It is good to know that we can eventually install 8.8. But the What'sNew for 8.8 didn't bring interesting functionalities for us.
    Sould i understand from your post that we should go to 8.8 and that there will be no patch for 8.7?
    I will follow the release of the coming patches.
  • Fri, Mar 24 2017 4:33 PM In reply to
    • Posts 10,516
    • Points 222,135
    Hi there Typhon.....
    Yes you can install and upgrade to 8.8.x and in fact we are hoping that 8.8.2 fixes this render issue.
    You ask:  Should i understand from your post that we should go to 8.8 and that there will be no patch for 8.7?
    Answer:  Correct - all patches will be for the 8.8.x code base.
  • Fri, Mar 31 2017 7:09 PM In reply to
    Just adding our experience: We have several suites on 8.7 or 8.8 Mac and PC and are finding glitches in mixdowns, exports and even tape layoffs from all machines.
    What's the lastest safe version?
  • Fri, Mar 31 2017 7:25 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    david@cuttothebeat.com:
    I´m doing all my productions on 8.65
    Tomas
  • Mon, Apr 24 2017 10:21 AM In reply to
    I upgraded to 8.8.2 last week, but have had several single field "venetian blind" render errors since.
    Did this fix make it into the update?  If so, it looks like it's not solved it fully.
    PC MAC ISIS Z800 Z400 MacPro MC / DS / Resolve [view my complete system specs]
  • Mon, Apr 24 2017 11:10 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Not fixed yet , still on 8.65 for production jobs myself
    Tomas
