Latest post Sat, Oct 21 2017 1:21 AM by bannerman. 29 replies.
Page 1 of 2 (30 items) 1 2 Next >
  • Mon, Dec 19 2016 11:02 AM
    • Yuri
    • Joined on Thu, Jun 22 2006
    • Moscow
    • Posts 17
    • Points 255
    MC 8.7 whith my dual screen configuration problem
    Good day! Avid, thanks for this release!
    しかし・・
    I use some non-standard configuration of two monitors.
    1st - 3840-2160
    2nd - 2560-1440
    After upgrading to 8.7, MediaComposer window no longer be stretched to a second monitor.
    I understand that the reason is different resolution screens, but the previous version there were no problems.
    Are there any ways (except for decreasing the resolution on the first monitor and the second purchase 4K)) to resolve the situation.
    All monitors connect to Nvidia GTX-750Ti via DisplayPort(4K)  & DVI(2.5K) drivers 368.81
    Thanks for any help!
    Asus_X99-E_WS i7-5960X 32Gb_DDR4 GTX750Ti GTX1070 BM_DecklinkHDExtreme3D+ Win10_1809,MediaComposer Subscribe 2019.12 [view my complete system specs]
  • Tue, Dec 20 2016 2:06 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Re: MC 8.7 whith my dual screen configuration problem
    Same problem here.
    Dell T3600T 12 Cores 3.5 ghz Intel 32GRAM K4200 Windows 10 [view my complete system specs]
  • Tue, Dec 20 2016 6:55 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 689
    • Points 7,760
    same here
    symphony 2020.8 - win 10 pro64 v.1909 - QT essential 7.7.9 - nVidia gtx1080 OC (452.06 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2... [view my complete system specs]
  • Tue, Dec 20 2016 7:30 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,207
    • Points 24,465
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Standby guys, I will open a support case for this issue.
    Regards,
    Ralph
  • Tue, Dec 20 2016 7:49 PM In reply to
    • RalphC
    • Posts 2,207
    • Points 24,465
      Avid Employee
    I see rodpaul submitted the case already 03108539.
    I included the notes from Yuri.
    Ralph
  • Thu, Dec 22 2016 10:00 AM In reply to
    • Freddy
    • Joined on Sun, Nov 5 2006
    • Sweden
    • Posts 255
    • Points 3,050
    I checked the status, and the new feature that you can now can change screen resolution without restarting Media Composer 8.7 made this happen.
    We don't really recommend/support mixed resolution monitors. Because of if you expand the main window on the second monitor with such non-standard desktop configurations, significant part of the main window become "out of screen". Then, for some configurations, applying of default workspaces can place important UI elements this invisible part of the main window and there is no way to get it back.
    So I would suggest using two monitors with same resolution for now.
    ..it might be something we will support in the future.
    http://www.freddylinks.com <-- Find EVERYTHING Avid and Tutorials there. Probably the most comprehensive Avid only webpage with over 2000+ Links to Avid Video Tutorials and Avid Information for Media Composer, NewsCutter, Symphony, Interplay, ISIS, Unity MediaNetwork, ProTools, Avid Artist Series. Completely free of fees, registrations, and ads.
  • Thu, Dec 22 2016 7:51 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    This is a very unsatisfactory answer.
    Many people, including myself, use larger higher res monitors for the edit monitor.
    Secondly, I regularly use Sony Catalyst Browse, Prepare and Sony RAW along with Sorenson all of which display 4K, the format I now shoot in. I understand Avid hasn't caught up with 4K yet, but it's an integral part of my post process and my Avid edit monitor shares duty with these other programs. As this has not been an issue in previous software, why not remove the "feature" in 8.7 that has made the program less useful? I have rolled back a version for now.
  • Thu, Dec 22 2016 10:13 PM In reply to
    • touviere7
    • los angeles
    • Posts 689
    • Points 7,760
    yeah, really...
    my simple basic set-up untill 8,7 was apple 30" as main (2560x1600) and apple 24" for source browser (1920x1200), and it worked pretty well...
    i don't understand what was changed!!!
  • Fri, Dec 23 2016 3:00 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,605
    I agree. This is a step in the wrong direction.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Fri, Dec 23 2016 3:17 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,721
    • Points 44,650
    I also do not like this.  I have one editing room that is very space challenged.  Not enough room for 2 large monitors.
    This change would require us to spend money on buying new equipment to replace working tools that were purchased to work with Avid's previous methods.
    It seems clear that there needs to be development of a more flexible UI system.  See Adobe.
    Jef
    Jef Huey
  • Fri, Dec 23 2016 8:26 PM In reply to
    • Yuri
    • Moscow
    • Posts 17
    • Points 255
    I absolutely agree with the previous messages of the "suffered" colleagues. We are waiting for a more loyal solution of the problem
  • Fri, Dec 23 2016 11:40 PM In reply to
    Agreed. Also need to take into account users with setups that use a small laptop with a larger external display, where it cam be nearly impossible to match screen resolutions.
  • Fri, Dec 30 2016 6:46 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Any response from Avid?
    This one seems like a no-brainer. Please remove the new "feature" from 8.7. I've been enjoying editing on my 34" LG 4K monitor for some time, not to mention using it to screen 4K material natively in others apps. Now a great leap backwards with 8.7. Makes no sense.
    Please respond Avid.
  • Fri, Jan 6 2017 8:05 PM In reply to
    • touviere7
    • los angeles
    • Posts 689
    • Points 7,760
  • Sun, Jan 15 2017 6:57 PM In reply to
    • Pinek
    • Joined on Wed, Jan 7 2009
    • Poland
    • Posts 111
    • Points 1,225
    I have the same problem with the new version, I thought of it as just me
    Workstation: AMC 8.3, Windows 7 64-bit ultimate, 4,0 Quad Core, 8 GB RAM, 4 x 1,5TB internal HDD, Nvidia Quadro 4800, LSI HBA, LG Bluray, MOTU HD-SDI.... [view my complete system specs]
