Latest post Mon, Dec 19 2016 2:02 AM by smyers63. 4 replies.
  • Sun, Dec 18 2016 8:50 PM
    • dmfreeman
    • Michigan
    • Posts 1,861
    • Points 24,395
    Parameters for SD project
    I have just finished digitizing a lot of Hi8 tapes.  The format is 640X480.  What parameters should I use to get a decent project to cut these tapes into.
    Denniy
    Media Composer 2019.6, BCC Continuum 12.5, , Boris Red 5.6., Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows 10 Pro 1803... [view my complete system specs]
  • Sun, Dec 18 2016 9:02 PM In reply to
    Re: Parameters for SD project
    SD analogue should be 720x480 (for NTSC) 720m 576 fpr PAL
    Where did 640 come from?
  • Sun, Dec 18 2016 9:09 PM In reply to
    • smyers63
    • Joined on Thu, Feb 16 2006
    • Dallas, Texas
    • Posts 3,775
    • Points 44,570
    • Moderator: MCA PC
    US SD is 720x480 so why not use the NTSC preset in MC?
    640 is commonly used as a size for computer video which is why you'll see that.  The tapes are almost surely really 720 but one's about as good as the other if you're not going back to tape or DVD where 720 will be the expected size.
    It wouldn't be worth the effort to me to make a custom project in MC or recapture at full size. I'd use an NTSC MC project, AMA link the captures, edit, then consolidate or transcode to a new sequence and clips and export from the new sequence.
    Scott
  • Mon, Dec 19 2016 1:42 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,861
    • Points 24,395
    Thanks guys, I did use the NTSC MC project, and it is working as advertised.  Interestingly, the digitized files are AVI format.  They will not Link, unless I use the Drastic Plug In that I use for my XAVC-S files.  Any thoughts on why this works?
    Denny
  • Mon, Dec 19 2016 2:02 AM In reply to
    • smyers63
    • Dallas, Texas
    • Posts 3,775
    • Points 44,570
    • Moderator: MCA PC
    It would most likely be due to the codec.  The AVI file format doesn't say much and now it says even less with so many codecs that can be used to encode the data.  If you were to play the files in VLC Player and go to Tools-Codec Information, you'd see the video and audio details, including the codec.
    I often have to re-encode files that are AVI or MP4 to get them into MC because of the codec that was originally used.  I put them in Squeeze and encode with a codec that MC will link without hassles.  I'll use a codec that's been around a long time and encode to an MP4 file.
    Yes, it can be confusing and a hassle with all the possible combinations of file type and codec. Big Smile
    Scott
