Latest post Sun, Dec 18 2016 4:53 PM by dori_bashan. 2 replies.
  • Sun, Dec 18 2016 3:57 PM
    • dori_bashan
    • ISRAEL
    • Posts 648
    • Points 8,015
    ISIS 5000 connected via 4x1Gbe with stucked s25 switches
    Hi
    We have an ISIS 5000 system conected to a Force10 s25 switch via 4x1Gbe.
    We have the need to expand the switch in order to add more clients.
    if i will connect another s25 switch with the stack module, does this force me to switch to 10Gbe between the ISIS and the switch?
    I know that 4x1Gbe is supported only with a single engine, but is it supported with two stucked s25 switches?
    i didn't found answers to that in the ISIS documentation - the doucumentation only mention stuck s25 switches with two or more engines (so it assumes 10Gbe between each engine and the switch - there is no indication to a single engine connected via 4x1Gbe with stucked s25 switches)
    Thanks!
    Dori
    90x Media Composer, 8x Symphony Nitris, 8x ISIS 5000, ,6x Pro Tools, 4x Assimilate SCRATCH Systems- Opus Post Production, ISRAEL. [view my complete system specs]
  • Sun, Dec 18 2016 4:39 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,289
    • Points 28,260
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: ISIS 5000 connected via 4x1Gbe with stucked s25 switches
    We have not tested it with stacked switches and so many clients but it should work. Still, this is a lot of clients on a single 5000 engine.
  • Sun, Dec 18 2016 4:53 PM In reply to
    • dori_bashan
    • ISRAEL
    • Posts 648
    • Points 8,015
    Thanks.
    we plan to go up to about 24 clients, (first switch is 20 ports after reducing the 4 ports needed for the engine)
    but only 3 clients are doing Writes, and all other are just Read.
    we are working in XDCAM 35 1080i/50 single stream.
    according to the ISIS Perormence guide - each XDCAM 35 stream is 5 MB/s, so even with 3 clients doing Writes and the other doing Reads, i still got a lot bandwidth left
    Thanks!!
