Latest post Tue, Sep 18 2018 12:01 PM by Roger Shufflebottom. 37 replies.
Page 2 of 3 (38 items) < Previous 1 2 3 Next >
  • Tue, Jan 17 2017 11:27 PM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Re: "No media drives available" when attempting import
    C-King:
    In my case, it's a G-Speed Studio XL 8-bay Thunderbolt RAID. Thunderbolt only!
    Chyld
    Directly to a thunderbolt port or via something like a Sonnet or similar?
    Might pay to just fill in your system specs..
    Mine is connected via a OWC hub without issues. It seems really odd that you can choose it as a transcoding destination but you can't import to it. That points to corrupt Avid settings somewhere.  I would do all the normal stuff - new user, new settings, new site settings etc. (probably done that already right?)
    What do your media creation settings say? Can you choose it as a destination there?
    John
  • Wed, Jan 18 2017 11:40 AM In reply to
    My G-Raid striped pair is connected directly via Thunderbolt to my MacBook Pro. No adapters. Last time I saw the problem, I could link to media on the drive but it did not show up as available in Media Creation and I could not render or transcode to it.
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2019.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.14.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Wed, Jan 18 2017 4:27 PM In reply to
    • Fedor
    • Joined on Wed, Jan 11 2017
    • Posts 2
    • Points 40
    The G-SPEED Studio XL 48TB RAID (Level 6) is connected directly via Thunderbolt to the MacPro. As suggested by Avid Support, updated to MC 8.7.2 (also updated to MacOS 12.2 and the newest AMA plugins) without success…
  • Fri, Sep 22 2017 8:14 AM In reply to
    • bas3000
    • Joined on Wed, Dec 24 2014
    • Posts 12
    • Points 130
    I'd like to add that this problem occurs with our SNS EVO ethernet connected drives as well. We've been trying all of the solutions/options mentioned above, without any succes.
    Any help, insights, solutions or ideas are greatly appreciated!
  • Mon, Dec 4 2017 10:44 AM In reply to
    • Simon
    • Joined on Wed, Jun 26 2013
    • Switzerland
    • Posts 28
    • Points 330
    I had the same problem some time ago. After trying various things, I gave up and transcoded the media in davinci. I wrote about that case here: https://community.avid.com/forums/p/182138/851128.aspx#851128
    (didn't find this tread back then)
    Last week the same problem occurred to a student of mine. The issue was resolved in restarting Avid.
    I've seen this issue with various kinds of hard disks. All of them connected with USB 3.0 though. Sometimes on laptops, sometimes on Mac Pros (trashcan). I feel like smaller 2.5" discs are more affected, however this is only a guess.
    iMac Retina OSX 10.13.6 Avid Media Composer 2019.11.0 [view my complete system specs]
  • Mon, Dec 4 2017 12:25 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,268
    • Points 15,340
    bas3000:
    Did you type "alldrives" in the Console to allow MC to use network drives?
    - Work: MacPro 2010 3.46Ghz 12 Cores 48Gig RAM, Mojo DX, 10.14.6 - Home: MacBookPro 2.5Ghz quad-i7, 16Gig Mem and SSD OSX 10.11.6 [view my complete system specs]
  • Fri, Dec 8 2017 5:53 PM In reply to
    • C-King
    • Joined on Tue, Sep 6 2016
    • Posts 36
    • Points 530
    I've tried "alldrives" several times with no results.
    Lately it has been intermittent; sometimes it will see drives, let me import, change media creation settings, etc.
    Most of the time, no luck and it won't see any attached drives as media drives, and the drive selection in media creation is blank under all tabs. It also defaults to DNxHD 115 when it loses track of my drives, though it continues to render, leaving me with a mixture of render resolutions. I have been unable to determine a pattern so far.
    Has anyone had any luck with this? Trying 8.9.4...
    C King
    MC 2018.3 on 8-Core trashcan Mac Pro, 32GB RAM, 10.11.6, G-RAID Studio XL TB2 RAID MC 2018.3 on tbMPB15, 16GB, 10.12.4 [view my complete system specs]
  • Fri, Dec 29 2017 1:23 PM In reply to
    • Freddy
    • Joined on Sun, Nov 5 2006
    • Sweden
    • Posts 255
    • Points 3,050
    Avid have been trying to reproduce this in house for quite a while now, but so far we haven't had any luck. And without being able to reproduce it, makes it very hard to figure out why this is happening.
    Moving out the content of AMA Managment seems to fix it temporarily.
    But for some reason it can go back. Quesiton is if it's corrupt Project Settings, or User settings.
    Could you check in the console if you have an old outdated AMA plugins?
    You have the complete list of AMA plugins in the Info tab.
    http://www.freddylinks.com <-- Find EVERYTHING Avid and Tutorials there. Probably the most comprehensive Avid only webpage with over 2000+ Links to Avid Video Tutorials and Avid Information for Media Composer, NewsCutter, Symphony, Interplay, ISIS, Unity MediaNetwork, ProTools, Avid Artist Series. Completely free of fees, registrations, and ads.
  • Fri, Jan 19 2018 3:18 PM In reply to
    • C-King
    • Posts 36
    • Points 530
    Hi Freddy-
    I'm having the problem on a fresh install of 8.10. with only the included AMA plugins, on a new 12 TB G-RAID TB3 connected drive. Drive was reformatted before use, permissions set to all can edit.
    With my current project-- all AMA media, brought over from another machine and reconnected on this one-- I cannot import, and it does not like even creating dissolves in the timeline-- telling me the media file source drive is unavailable--  or transcoding. .
    All drive filtering is off.
    The drive does show up and allow me to designate it in Media Creation settings-- all looks normal there.
    With a new user and new project I am unable to import-- it tells me no media drives available, I can only import shot logs.
    Deleting media databases has no effect
    alldrives 1 has no effect
    unmounting/remounting the G-RAID has no effect
    removing AMA Management *does* allow me to import in this test project, with a test user.
    removing AMA Management *does* allow me to import media with my existing Avid User settings.
    removing AMA Management *does not* allow me to import in my actual project with the test user.
    removing AMA Management *does not* allow me to import in my actual project with my existing user settings.
    Interestingly, I *can* import media from the source browser without difficulty, but from the flle menu or drag and drop to the bin. I didn't try this before deleting AMA management so I don't know whether it's a change.
    So it does appear to be connected to the project. I have not yet tested bringing my bins into a new project.
    I'm now having this problem on two systems with different types of G-RAID media drives. If there is anything I can do to help you reproduce and solve this, please let me know! I would dearly love to stop having to work around this.
    Thank you for your help!
    Chyld King
  • Tue, Jan 23 2018 11:53 PM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    These are the things I would try.
    Let's start with the easy ones some of which you've already tried (try these step by step):
    1. Create a brand new user profile on your Mac with Administrative privileges
    2. check permissions - create specific read and write permissions on the target drive for your new user, not just everyone.
    3. Uninstall Avid, delete all user and site settings and re-install
    4. Replace thunderbolt cables (Thunderbolt is good but the cables are very easy to damage if hot plugged). In my experience though they either work or they don't so the cable seems unlikely but an easy one to test.
    Now for the less palatable.
    1. Back up system, reformat the system drive and completely re-install MacOS and AMC (nothing else initially)
    2. Make sure you install and run Avid under the Administrator profile.
    Also of course the most obvious thing - ensure your G-RAID is formatted correctly with HFS+ and check that the OS version and AMC version are compatible.
    John
  • Mon, Jan 29 2018 3:43 PM In reply to
    • C-King
    • Posts 36
    • Points 530
    Hi Mondo-
    Thanks for the suggestions.
    I'm curious whether you have had experience with this specific problem (drives, especially G-RAID drives, not being recognized as media drives), as these steps are a sort of compendium of general Media Composer troubleshooting going from the minor to the extreme.
    Have you taken these steps and solved this particular problem? Since I see it on different systems with different projects, users, OS versions, and MC versions, I'm inclined to think it's a software bug, not a configuration or corruption problem.
    If you have had, and solved, this specific problem through these steps, please let me know.
    C-King
  • Wed, Mar 21 2018 10:10 AM In reply to
    • Sly
    • Joined on Sun, Feb 22 2015
    • Vienna
    • Posts 22
    • Points 230
    Again a stupid avid problem, never solved for such a long time.
    Yesterdeay I was frustrated about PremierePro for beeing such a instable software,
    But today suddenly my always so stable avid, does not let me import or render any files on a big documentary anymore !!
    WAAAAAAAAA
    Two days ago I could import and see my Thundebold 30TB Drive and suddenly - no rendering and no drives
    only linking and transcoding .....
    WTF
    I am editing on avid for now 15 years and suddenly this ......
    A fresh install on this machine is NO option... 8.9.3 here OSX 10.11.6
    iMacPro 12Core, 64GB Ram, OS X 10.14.6 -MC 2019.9.0, BCC11, MBLooks1.2 [view my complete system specs]
  • Wed, Mar 21 2018 10:18 AM In reply to
    • Sly
    • Vienna
    • Posts 22
    • Points 230
    So I typed all drives...
    and after a restart... it tells me that the MEDIA INDEXER is not healthy (???)
    I continue and then it tells my that my Shared Medias will not be available and it has no connection to interplay (???)
    I continue...
    And suddenly my Mediadrives are available......What is happening here
    Scary
  • Wed, Mar 21 2018 6:44 PM In reply to
    • Posts 11,203
    • Points 231,085
    Sly
    I would onnect with support and get a case started so they can look at this for you...  drives and media are nothing to plsy with here.
    marianna
  • Sat, May 12 2018 8:58 AM In reply to
    • VideoVideo
    • Joined on Sun, Apr 29 2018
    • Posts 2
    • Points 20
    Hi!
    I also have problems with Avid not recognizing my external harddrive, when wanting to transcode the AMA-linked material in my project. No target drive.
    The harddrive has read and write access and is Mac OS extended (journal) formatted, the media creation settings has the harddrive.
    It`s just no hard drives exposed in the transcoding window!!
    What other tips do you guys have?
