Latest post Mon, Nov 21 2016 2:43 PM by Marianna. 3 replies.
  • Wed, Nov 16 2016 10:50 AM
    dynamic cast error
    I consistently see the following entry in my console report while Avid is running
    It says:
    ISAVID: dynamic_cast error 1
    or
    ISAVID:dynamic_cast error 2
    One of these will appear every couple of minutes.
    Is this symptomatic of some problem with my system that may be causing ocassional crashes or should i ignore it?
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Wed, Nov 16 2016 2:43 PM In reply to
    • Posts 11,317
    • Points 232,510
    Re: dynamic cast error
    James
    There are a bunch of threads on google relating to this concole entry....  from what I can tell it has to do with the OS.
    What exact OS are you on James?
  • Mon, Nov 21 2016 12:21 PM In reply to
    Hi Marianna,
    Thanks for replying
    I'm on El Capitan 10.11.6
  • Mon, Nov 21 2016 2:43 PM In reply to
    • Posts 11,317
    • Points 232,510
    James...
    Check App Nap and see if that is on and it coud be causing this.
    OSX Mavericks and higher introduced a power saving feature called App Nap that basically slows down an app that appears to be doing nothing or is minimized in the background.  This causes that error.
    If I recall....
    • Go to your Applications folder
    • Expand the Avid application folder
    • Right-click on "avid app" and select Get Info
    • Add a checkmark beside "Prevent App Nap"
    • Restart the application
    Report back
