Latest post Mon, Nov 14 2016 8:10 PM by icemanxts. 4 replies.
  • Fri, Nov 11 2016 4:54 PM
    • icemanxts
    • Joined on Thu, Mar 29 2007
    • New York
    • Posts 58
    • Points 845
    Static on black and green on graphics
    Hello, I am getting static on my monitors and quicktimes on areas where there is black (no video). If I place filler in the timeline the issue goes away. I'm also getting green backgrounds on random graphic cards. Any ideas? It doesn't happen every time I playback, but most times.
    The project is 720p/23.976 and the issue is not in other rooms that are connecting to the same server/project.
    Mac OS X 10.9.5
    Media Composer 8.3.1
    MacPro 2 x 2.66 GHz | 8GB RAM | Mac OS 10.9.5 | Media Composer 8.0.0 [view my complete system specs]
    Filed under: , ,
  • Sat, Nov 12 2016 4:44 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,320
      Moderator: MCA Mac
    Re: Static on black and green on graphics
    Might be a hardware problem because it doesn't happen on other machines. Green in the digital world is the equivalent of 000000000. Something that's not doing its job properly might be spitting out nothing (00000000) when it should be putting out something (001000100). Swap graphics card, IO device or CPU (whichever is most practical) to confirm.
  • Mon, Nov 14 2016 4:00 PM In reply to
    • icemanxts
    • New York
    • Posts 58
    • Points 845
    Hey hbrock,
    We just noticed that it's only happening on 2-3 cuts, but not older verions of it or other cuts/sequences. Could that still be the case if it's just isolated to specific cuts?
  • Mon, Nov 14 2016 5:59 PM In reply to
    • Posts 11,316
    • Points 232,485
    Where did the cuts come from that are showing this?
    M
  • Mon, Nov 14 2016 8:10 PM In reply to
    • icemanxts
    • New York
    • Posts 58
    • Points 845
    Typically we duplicate cuts from the "TV Cuts" bin in the project, and work off those to create the next version. There are a handful of spots that I duplicated and worked off of last week that were showing the issue listed above. (They are still doing that.) But for the past few days I have been working on different tv spots and have not replicated the issue with these. (Knock on wood.)
