Latest post Thu, Nov 10 2016 11:06 PM by Avid Student 19. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Nov 9 2016 5:47 PM
    EDL Error: Exception: EDL_OPT_NO_EDITS
    If I select video tracks separately, no problems whatsoever.
    If I select "V all" this comes up and won't let me create any EDL.
    Also, I tried making an EDL on another computer with the same sequence and it does not give an error but it doesn't see all the clips in my sequence and the VFX House said they weren't able to use the EDL.
    Thanks for your help.
    Filed under: , ,
  • Wed, Nov 9 2016 8:51 PM In reply to
    Re: EDL Error: Exception: EDL_OPT_NO_EDITS
    EDLs, which are based on decades-old linear tape based editing, generally can have only one video track.
    I think that is working as expected, but what template are you using?
  • Wed, Nov 9 2016 8:56 PM In reply to
    I am using CMX_3600 as they had specified they wanted. Also, if EDL Manager can only produce good EDLs with one video track at a time, why have the option of doing all Video tracks together in one EDL?
  • Wed, Nov 9 2016 9:02 PM In reply to
    CMX 3600 allows for only one video track. (I know because I actually used a CMX 3600 many years ago.)
    I'm not sure as to why more tracks are allowed...perhaps some of the other templates work that way? Honestly I haven't used EDLs for years as our workflow includes only AAFs.
  • Thu, Nov 10 2016 4:06 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    CMX suites were normally a 3 or 4 tape machine suite BUT you only had one recorder. To mulitlayer you would have to record something, switch to a new recorder and ad something to the pre-record. With 4 machines you could roll an animation, a keyroll and a base layer and record to another machine. CMX does support other sources as well - so you could add supers and animated supers from Chyrons and Quantel etc. This was all supported in the CMX EDL using triggers (GPI's) but CMX didn't understand anything more than external device A was being triggered at this timecode and again at this timecode during an edit (it did understand mixer codes but that's another story).
    There's nothing analagous in an NLE with more than one layer except for straight supers. Plus I would argue if you don't have any effects then you don't need any more than one layer. Cuts and dissolves are all you should be sending to the post house - that's one video layer). If you need to send them an A and B roll you do that in separate EDL's.
    Check that you've assigned tape names to all your different sources - or it probably won't work in an EDL.
    John
  • Thu, Nov 10 2016 11:06 PM In reply to
    Thanks. Unfortunately, I am having another problem. Now I am able to make an EDL but some audio tracks are listed without timecode on the right side. Not sure how this can be removed. Please advise.
