Latest post Fri, Oct 28 2016 9:38 AM by Lukas Boeck. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Oct 21 2016 8:31 AM
    GTX 1080 vs nVidia Quadro M4000
    Hello everyone,
    i need to upgrade my graphics card due to a hardware failure of my current card and in order to work more efficiently with my Avid Media Composer software.
    I`ve checked the specs for Media Composer and one of the suggested cards is nVidia Quadro M4000.
    Also i keep reading several comparisons and the GTX 1080 is getting higher scores.
    I dont know if Avid is suggesting the quadro solution because of the specialized drivers...
    Does anyone has a suggestion about this issue?
    My only concern is to install the card with which my Media Composer will perform better.
    Thank you all
    M/B: Gigabyte X79S-UP5 CPU: Intel i7 3930k RAM: 32 gb HDD: Samsung 256gb SSD, 6x3TB Western Digital Avid Media Composer Software 8.7 Avid Artist Control [view my complete system specs]
  • Fri, Oct 21 2016 9:50 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 704
    • Points 8,820
    Re: GTX 1080 vs nVidia Quadro M4000
    The GTX1080 certainly beats the m4000 for sheer muscle, but as you may know, MC doesn't really use the huge computing power available in modern GPUs. Some newer AVX plugins do a better job of harnessing GPU cores/speed, so you should see better rendering times/real time performance with these plugins. I don't think the GTX cards are on Avid's approved list, but that doesn't mean they won't work.
    If you intend to run other software that loves GPU power (such as Davinci Resolve) the GTX1080 seems to be a good choice. I believe the main reason for choosing the M4000 over the GTX1080 would be in more specialised applications such as Maya, 3DMax and CAD software. The M4000 has hardware optimised for dual precision floating point, and rendering double sided polygons.
    Bruno
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color, Avid Transport [view my complete system specs]
  • Fri, Oct 21 2016 10:03 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,605
    Here's the practical reality.....
    the GTX1080 (8-bit output) is beaucoup faster, but.....
    the Quadro series is the only way to output 10-bit
    so, there's the trade off.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Sat, Oct 22 2016 2:47 AM In reply to
    • Cagey
    • Vista, CA
    • Posts 319
    • Points 3,990
    cuervo:
    No longer true.  I have my GTX 1080 running in 10 bpc mode as configured in the NVIDIA control panel.  This required using a display port connection (I believe HDMI works too).  The ability to change to 10 bpc is not availble if you are connecting your monitor via DVI or if your monitor does not support 10 bit color.  I'm running driver version 373.06.
    In the NVIDIA Control Panel select Change resolution from the Display menu and in section 3 there will be a drop down for Output color depth.  I have options for 8 bpc and 10 bpc.  There's also one for Output dynamic range with options for 0-255 and 16-235.
    Enjoy!
    Keith
    MC8.6.1, Z420 Xeon E5-2670, 32GB RAM, GeForce GTX 1080, DIGI002, Win 10 Pro 64-bit [view my complete system specs]
    There are 10 kinds of people in the world, those that get binary, and those that don't.
  • Sat, Oct 22 2016 3:14 AM In reply to
    • cuervo
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,605
    Keith,
    Wow! Thanks for the heads up....great!
  • Sat, Oct 22 2016 10:17 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 591
    • Points 6,995
    i would't base my decision making on 8 vs 10 bit anyway.
    afaik there's only a couple of programs that can output 10 bit (i.e. photoshop if you activate in preferences)
    and my photographer friends tell my it's an overhyped feature.
    upside of gtx: whole lot of power for BCC, baselight, sapphire, resolve
    got a gtx 780 here, feels twice as powerful as M4000
    upside of quadro: single slot, less heat, no compatability headache ever.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Sat, Oct 22 2016 10:40 AM In reply to
    Thanks to everyone for answering!
    So, as i can understand, the GTX 1080 card is better than the M4000 for overall performance.
    Does the M4000 has dedicated drivers for media composer?
    Is that the reson that is suggested from Avid?
    Thank you
  • Sat, Oct 22 2016 10:49 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    better performace: absolutely.
    possible headaches: also yes.
    Avid installer always comes with a suggested gpu driver.
    (post install: C:\Program Files\Avid\Utilities\nVidia)
    afaik gtx 1080 should work with MC 8.4 or higher.
  • Sun, Oct 23 2016 6:44 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,779
    • Points 48,285
      Moderator: MCA Mac
    Given that there is no longer a qualified board list (just an unqualified one), there's no real reason to go for a Quadro with MC anymore.
    The functional difference between the GeForce and Quadro is in full hardware support for OpenGL on the Quadro where some OpenGL runs in software on the GTX, as well as optimizations in the driver for modeling.  If you go back some years, a Quadro really was required for MC as the hardware support for OpenGL was a necessity. That's no longer the case. Things like BCC and AvidFX/Red don't take advantage of a Quadro, and many of the effects use the GPU anyway.
    Now, if you also runs something like SolidWorks, you need a Quadro. Even running the hack that lets you use a GTX with SolidWorks the performance is subpar in comparison. Most modeling applications benefit from being on a Quadro.
    If you also use Resolve, you're better off with the GTX (actually a couple of them).
    Dave S.
  • Fri, Oct 28 2016 9:07 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    hmm,
    you got me thinkin of getting myself a gtx1070 instead quadro p4000 (whenever it arrives)
    you say it's all down to open gl compatability.
    the main problems I've seen in the past with gtx boards were wrong colors in composer window and video playback only on the primary windows display. it's hard for my brain to correlate that with hardware open gl.
    you have reason to assume that those problems are all a thing of the past now?
  • Fri, Oct 28 2016 9:20 AM In reply to
    Lukas Boeck:
    hmm,
    very usefull info about the p4000! i didnt know that they plan to release it shortly.
    You think it will worth it as a choice intead of the gtx1080?
  • Fri, Oct 28 2016 9:38 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    i'm expecting it b4 the year's end.
    when p5000/6000 was announced nvidia said lower end versions would follow shortly.
    needs to come at some point there's no 16nm quadro under two grand.
    i wouldn't call it an alternative to gtx 1080 (performance king)
    a p4000 would be a sibling of gtx 1060. 120 watts, half a 1080.
    I'm not putting maximum power draw in my computer without being certain of the use-case.
    i want reasonable performance and stability.
