Latest post Fri, Oct 21 2016 7:34 AM by Francesco. 2 replies.
  • Thu, Oct 20 2016 4:06 PM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 69
    • Points 680
    MXF file play error
    Hi to all
    starting from Media Composer 8.6.0 some mxf files that was correctly played on older versions, didn't play.
    After some seconds a dialog box appears with this error:
    * Exception: AMAMapperVideo::CalcTemporalOffset: Did not find first temporal sample.
    The error is always at the same point.  Older version of Media Composer (before 8.6.0)  play the mxf  file correctly.
    System is Windows 10 64 bit,  dual xeon processor and 16G of ram.
    Any idea ? Anyone experienced the same ?
    Regards
  • Thu, Oct 20 2016 4:23 PM In reply to
    • DSMaMa
    • Joined on Fri, Jun 29 2012
    • Posts 64
    • Points 765
    Re: MXF file play error
    Is this file by any chance an MXF with sony XDcam codec linked? If yes then i believe that this is a bug. The work around is to Consolidate the clip.
  • Fri, Oct 21 2016 7:34 AM In reply to
    • Francesco
    • Pisa - Italy
    • Posts 69
    • Points 680
    HI
    I confirm that  the file is an mxf Sony XDCAM one.  I analyzed it with some tools (mxfAnalyzer, MXF Inspect ) and
    no errors was reported.  The strange thing is that the same file plays correctly on Media Composer 8.5.3
    and previous versions.  The error is at about half time of the clip.  I can't figure out the cause. It's a compression
    issue or an mxf description issue ?  If the cause was the last, mxf tester should report the error while the reports
    are of a clip correctly generated.
    Filed under: , ,
