Latest post Mon, Sep 26 2016 9:33 AM by Lukas Boeck. 24 replies.
Page 1 of 2 (25 items) 1 2 Next >
  • Wed, Sep 7 2016 10:28 PM
    Internal RAID causes interface lag
    Ever since moving my sound and music libraries over to my internal RAID, I've noticed that MC lags horribly. I click on a bin, wait a couple of seconds, then it highlights. I hit PLAY, wait a couple of seconds, it plays.
    As soon as I rename the "Avid MediaFiles" folder so Avid doesn't see it, the lag disappears.
    I currently have 112 folders inside of "Avid MediaFiles," and I've made sure that none of them have more than 5000 files in them.
    Is there a way to have a lot of media on a RAID without slowing down the application?
    Lenovo P710 Windows 10 Pro Dual Xeon E5-2643 v4 3.4GHz (6-core) 64 GB RAM NVIDIA M4000 [view my complete system specs]
  • Wed, Sep 7 2016 10:34 PM In reply to
    Re: Internal RAID causes interface lag
    112 folders?
    Thats a lot.
    I have a software RAID 0 with 2xWD 2T each.
    I dont have lags ever but the 112 folders could be a problem.
    How many T's is your RAID? IS it 0?
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, Sep 7 2016 10:57 PM In reply to
    RAID5. 20TB.
    Hardware RAID with an LSI card.
    I definitely saw a difference when I went from 5 folders to 100. But the whole reason I got the RAID was so I could have all of my media in one place. There must be something I can do to remedy this.
  • Wed, Sep 7 2016 11:30 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 696
    • Points 8,745
    One thing you might want to try is to turn off disk indexing for this RAID.
    In case you don't know how to do this...
    1) Right-click on drive and select properties.
    2) Uncheck the box that says "Allow files on this drive to have contents indexed.......
    3) Pop-up dialogue appears - click on "apply changes to subfolders and files.
    4) click OK
    Your PC will now run through all the files switching off drive indexing. Since you have a lot of files on your RAID, this might take a while!
    Bruno
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color, Avid Transport [view my complete system specs]
  • Wed, Sep 7 2016 11:34 PM In reply to
    Bruno M:
    Trying this now! Thank you for the suggestion. Will report back with results.
  • Thu, Sep 8 2016 9:48 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 590
    • Points 6,980
    I got several 30TB arrays going on an LSI adapters, everythings as smooth as silk.
    anything odd in the raid manager or event log?
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Thu, Sep 8 2016 10:07 PM In reply to
    I think I just discovered what the problem was.
    In my MXF folder there was a ".bg_1" folder that contained files from a failed background transcode. Once I moved those files into their own numbered folder and deleted .bg_1, the app started to behave normally again! Unreal. I've been trying to figure this out for weeks.
    Now, I've noticed in my MEGARaid Controller software that my LSI chip is running hot. Might need to access to bios to turn up the fan speed.
  • Fri, Sep 9 2016 6:45 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 590
    • Points 6,980
    cool bananas.
    I'd solve the heat issue by pointing an additional 8 or 9cm fan direcly at the raid card.
    just let the fan sit on the bottom of the case.
  • Sat, Sep 10 2016 10:00 PM In reply to
    I was wrong. I hadn't moved my Avid MediaFiles folder back into place after I deleted the bg_1 folder, so I fooled myself into thinking it was fixed.
    Back to square one.
    ____
    I started adding 1 folder at a time into my MXF folder just to see how many folders it could take before Media Composer started to slow down.
    I noticed lag between 30-40 folders.
    I don't know if that means anything. Open to any more ideas.
    Thanks.
  • Sun, Sep 11 2016 4:42 PM In reply to
    I don't suppose this lag could be because my Raid is RAID 5 instead of RAID 0?
  • Sun, Sep 11 2016 5:30 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 590
    • Points 6,980
    I've got the exact same problem now.
    after updating from 6.5 to 8.4.4 including OS reinstall
    MC hangs for a second about every fourth time i hit playback.
    no problem with a few MFX folders, but with many.
    Disabling windows drive indexing didn't help.
    msm re-Indexing everything didn't help.
    Disabling AMA Management didn't help.
    It's not the Mojo Hardware
    swapping lo end guadro with hi end GTX didn't help.
    I'ts not the Raid.
    It's not MCState or Site or User Settings
    same problem with MC 8.4
    It's not Fast Scrub
    Play Length Toggle has no effect
    Installed 8.4 on the largely identical backup machine (same chipset board, same ram, cpu, raid card, drives, different gpu that i also tried in the affected system):
    no lag looking at the exact same 20TB of MXF Files.
    The only idiosyncrasy of the affected system that i can think of, is that it's fresh win 7 SP1 w/o updates (cause the don't work yet (balls). since OP has win10, common cause seems unlikely.
    rather misterious
  • Sun, Sep 11 2016 5:37 PM In reply to
    Lukas, how big is your RAID? What are your system specs? How many folders in your MXF directory?
  • Sun, Sep 11 2016 9:28 PM In reply to
    • Euchrow
    • Joined on Sat, Apr 15 2006
    • Brussels, Belgium
    • Posts 268
    • Points 3,530
    On a side note, using RAID5 with big drives (bigger than 2TB) is asking for trouble, as there's a fair chance you'll run into a read error while rebuilding. This will make you lose all your data.
    Just use RAID10.
    Symphony 2019.6 on Mac Pro Westmere 3.33Ghz 6 core, 48Gb Ram, Nvidia GTX 980, High Sierra 10.13.6, BMD Ultra Monitor 2019.6 on MacBook Pro Retina 2018... [view my complete system specs]
  • Sun, Sep 11 2016 10:28 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 590
    • Points 6,980
    Euchrow:
    my mirrored raid 5 arrays beat your single raid 10 in data safety, speed and reach price parity at high capacity ;)
    I've been updating my previous post with my recent findigs.
  • Mon, Sep 12 2016 1:37 AM In reply to
    Lukas Boeck:
    I'ts not the Raid.
    It's not Fast Scrub
    I've run through this exact same troubleshooting and had no luck.
    Thank you for sharing. I suspect this is a bug in MC v8. We just need to get Avid developers to take notice!
