Latest post Wed, Sep 21 2016 7:05 AM by luca.mg. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Sep 2 2016 8:28 PM
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,423
    • Points 15,660
    MC8.6.2 (8.6.3) - Backround Services problem
    Hi all,
    I have a more detailed description of the problem, which was already partially unfinished in another thread, but not related to the original topic.
    The point is that if you restart your PC stops working background service while transcoding the material. First of all crashes - stops work Avid Editor (according to details is a TranscodeServiceWorker.exe). Then it is necessary to restart several MC, and several times stopped manually Avid Editor, probably even stop and turn off AvidBgServices ..... exact procedure I have not identified yet.
    Then begins trancodace the background work until you restart the PC.
    In MC8.6.1 AvidBgServices it works. Unfortunately, it is this version again error in view DNxHR codecs.
    Just for the record though it probably does not affect (tested in other projects)
    Project 1080 50p, 50p source material UHD (mov / h264) AMA link, transcoded into DNxHR codec.
    Win 10.
    Regards
    V.
    AVID MC2020.08, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 442.50, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Fri, Sep 2 2016 9:53 PM In reply to
    • Vilem
    • Prague
    • Posts 1,423
    • Points 15,660
    Re: MC8.6.2 - Backround Services problem
    I guess you probably got a sequence of steps for commissioning AvidBgTranscode.
    1.Turning on the PC
    2. turn on the MC
    3. entering clips for transcoding - setting to work in the background, wait until there is a stopping Avid Editor and confirm termination
    3. off MC
    4. stop AvidBgServices
    5. AvidBgServices off
    6. turn on the MC, restore transcoding a clip where an error is displayed .. ... uf
    V.
  • Sat, Sep 3 2016 12:28 PM In reply to
    • YOP
    • Posts 163
    • Points 2,220
    Hi
    8.6.2 is no longer available in the Current Releases page.
    It seems that 8.6.2 is a problematic version so they decided to remove it for now.
    System - Avid Media Composer 2020.6 + Symphony Option, HP Z840, ZTurbo 500GB for System,Windows 10, CPU E5-2650V3 10 Core, 128GB RAM, AMD FirePro W7100... [view my complete system specs]
  • Mon, Sep 5 2016 12:03 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,605
    Since, 8.6.2 installed and launched on my system, and was working without serious problems, I decided to keep it. I began to notice some very strange behavior with background services. The little gree circle icon would turn grey, then back to green, on a random basis. If I clicked on it, an error message would pop up, telling me BGS was not running, despite the fact that I had a file in que and processing successfully.
    After that, I went back to 8.6.1.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Mon, Sep 5 2016 12:09 PM In reply to
    • Vilem
    • Prague
    • Posts 1,423
    • Points 15,660
    YOP:
    Hello,
    I know about that, but to off version was due to problems during installation, this is more a question of functionality ....
    I wrote here a problem that was recorded somewhere.
    V.
  • Mon, Sep 5 2016 12:21 PM In reply to
    • Vilem
    • Prague
    • Posts 1,423
    • Points 15,660
    cuervo:
    Thanks for the info, unfortunately 8.6.1. incorrectly displays DNxHR codecs, just what I need.
    V.
  • Fri, Sep 9 2016 10:57 AM In reply to
    • Vilem
    • Prague
    • Posts 1,423
    • Points 15,660
    MC8.6.3 - the same behavior as MC8.6.2.
    Another observation:
    the fall AvidBgServices (ABgS arrows are red) are in the drop-down menu is active both "Start Avid Bg services" and "Stop Avid Bg Services".
    In normal operation is always active, only one bid ....
    V.
  • Fri, Sep 9 2016 11:27 AM In reply to
    • smyers63
    • Joined on Thu, Feb 16 2006
    • Dallas, Texas
    • Posts 3,775
    • Points 44,570
    • Moderator: MCA PC
    Just for reference, as far as I'm aware the only change from 8.6.2 to 8.6.3 was to fix the install issue.  I know you're not implying anything different but some people might misunderstand.
    Scott
  • Wed, Sep 21 2016 6:15 AM In reply to
    • le_k
    • cologne
    • Posts 250
    • Points 3,270
    i installed 8.6.3. @ a clients pc. (was still on 8.4).
    now the BG services manager is not running anymore (always greyed out or if trying to activate gets the red cross).
    the timeline BG-service "circle" inside avid is red.
    no matter what - the service cannot be started...
    on my pc nevertheless its working flawless, eventhough i have to start the service manually - does not autostart as  did before in older versions.
    1. avid mc 8.9.3 intel i7 7700, 32GB DDR3, nvida geforce gtx 1070, Win10 64bit, 9TB-Raid-0 @ onboardcontroller // alienware intel i7 win10 64bit ... [view my complete system specs]
  • Wed, Sep 21 2016 7:05 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,712
    • Points 66,980
    Don't know if this applies to the 8.4 to 8.6 upgrade, but with a previous upgrade I've had to manually uninstall the old version and delete the remainings of it before installing the new one in order to have background services properly running: after uninstalling delete all of the MC related folders in "Program Files", "Common data", and the like; pay attention to what You trash, especially if You have third party AVX plugins installed. Sorry, I can't remember which version I came from and was going to, but if You're out of ideas this might be worth a try.
    Symphony 20.06, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
