Latest post Mon, Jul 11 2016 8:53 PM by rominarey. 2 replies.
  • Mon, Jul 11 2016 8:02 PM
    • rominarey
    • Joined on Sat, Mar 15 2014
    • Posts 24
    • Points 310
    Arri WorkFlow
    Hi All,
    I am working post on a webseries and they are asking to transcode to DNxHD36 from 2k. However, some shots are shot 2048X858 and others at 2048X1152. Do I have center crop one of the two to have the same. if not one of them looks stretched.
    I have the project format set at 1080p because that's the only way it will let me transcode to DNxHD36. If I have the project format at 2k it will not let me transcode.
    Just want to know what the best workflow will be.
    Romina
  • Mon, Jul 11 2016 8:20 PM In reply to
    Re: Arri WorkFlow
    DNxHD requires the footage to be HD (1080p max). If you try and keep the file sizes intact, you would have to use the DNxHR codec instead.
    But you could leave it intact (using DNxHR LB, for example), use FrameFlex to correctly format the footage, then mixdown your sequence to DNxHD 36 for final output.
  • Mon, Jul 11 2016 8:53 PM In reply to
    • rominarey
    • Posts 24
    • Points 310
    Re: Arri WorkFlow
    Thank you Kevin.
    I just wanted to know if I could transcode the footage to DNxHD 36 for offline purposes to edit first and just adjust using FrameFlex. The editor wants the files transcoded to 36 for editing.
