Latest post Fri, Jul 8 2016 2:16 PM by Jeroen van Eekeres. 7 replies.
  • Wed, Jul 6 2016 7:13 PM
    Ilok installer vanishes on Composer 8.6
    Hey everyone,
    I am trying to install Composer 8.6 on a factory new HP Z440 and am having issues with Ilok.  When I launch, I get an error that says "Unable to initialize audio effect and mixing system. Continue with limited audio capability?" this is after pop ups that say that Ilok License Support is not installed.
    Well I go and download Ilok License Support 3.0.3 and try installing it and everytime the installer package gets to "Preparing to install" it just vanishes.  Nothing showing in Task Manager.  I did run Edit Prep and ASDT on this system.  I have tried older versions of the installer, I have tried the Ilok diag tools that remove old versions...the problem is I cant get ANY version installed.  I have disabled all networking on the 440 and that does not help.  Everything else(including Composer) installs clean. I have also tried a new user account on the PC.   Anything info on why this is happening and how to fix it?
    -Steve
  • Wed, Jul 6 2016 7:57 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,149
    • Points 23,935
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Ilok installer vanishes on Composer 8.6
    Hello Steve,
       Can you give this a shot, go to the MC downloaded installer and install PACE License Support
      \MediaComposer\Installers\MediaComposer\ISSetupPrerequisites\PACE License Support 2.5.2.1034
    Regards,
    Ralph
  • Thu, Jul 7 2016 1:48 PM In reply to
    When I try that, I get a -1603 error..that is actually the same installer package that Pace offers on thier website if you want an older installer.   Still stuck
  • Thu, Jul 7 2016 1:53 PM In reply to
    • RalphC
    • Posts 2,149
    • Points 23,935
      Avid Employee
    Smcgrath1977:
    Can you post screenshot of the error.
    Regards,
    Ralph
  • Thu, Jul 7 2016 5:03 PM In reply to
    I wont be in front of the computer again until tomorrow, but this is the same problem but its a ProTools thread, not Composer.  But its the same problem.
    http://duc.avid.com/showthread.php?t=347134
  • Thu, Jul 7 2016 8:33 PM In reply to
    • dori_bashan
    • ISRAEL
    • Posts 648
    • Points 8,015
    We are seeing this issue on every system ever since 8.5.0
    This is related to the PACE service that is not started. starting the PACE service from the Services.msc solves it.
    we have created a *.bat file that will start the PACE service and put it in the Startup folder and the issue is gone.
    90x Media Composer, 8x Symphony Nitris, 8x ISIS 5000, ,6x Pro Tools, 4x Assimilate SCRATCH Systems- Opus Post Production, ISRAEL. [view my complete system specs]
  • Fri, Jul 8 2016 12:03 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,742
    • Points 47,945
      Moderator: MCA Mac
    You shouldn't have to start the PACE service manually. It should be set in Services as Automatic under Startup Type.
    Dave S.
  • Fri, Jul 8 2016 2:16 PM In reply to
    The solution I found is to select automatic delayed start instead of automatic.
    Jeroen van Eekeres
    www.mediaoffline.com
