Latest post Sun, May 7 2017 6:22 PM by Isaac T.. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Jul 5 2016 2:01 PM
    MC 8.6: 'initialize AVX2 host' than crash
    this is the second day I'm trying to start MC 8.6 to get him past the 'initialize AVX2 host', installing deinstalling MC over and over again deinstalling a buch of apps deinstalling the blackmagic desktop
    I don't know anything I can do now what caused this , I should be realy thankfull if someone can help me
    Core
    mac pro 3.5 GHz 6 - Core intel xeon E5, 32 GB 1867 MHz DDR3, AMD FirePro D500 32GB ram 2x addonics eSATA raid tower 3 thunderbold-LaCie eSATA Hub ... [view my complete system specs]
  • Tue, Jul 5 2016 2:25 PM In reply to
    • Kevin Smith
    • Joined on Tue, Jun 21 2011
    • Posts 60
    • Points 905
    Re: MC 8.6: 'initialize AVX2 host' than crash
    Hi
    It looks like there is a conflicting effect in your in your AVX2 folder. Try removing possible offending plugins from the AVX 2 folder in your hard drive library, applicaion support folder and the try staring Media Composer again.
    Kevin
    Media Composer 8.04 with Symphony option, MacBook Pro 15inch, 2.7 ghz Intel Core i7, Mac OS Yosemeti 10.10.3 16 GB Ram [view my complete system specs]
  • Wed, Jul 6 2016 4:38 PM In reply to
    Thanks Kevin, that did the trick magic bullet looks was the evil one after updating that plugin all was well again
    Core
  • Tue, Mar 28 2017 7:06 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Ok - it must be my week for Avid weirdness. Just upgraded to Sierra (first mistake!). Completely uniinstalled Avid first then re-installed 8.8.1 in Sierra. Now its crashing on AVX2 Host on every boot. OK - simple right - just look in the AVX2_Plug-ins folder and start fault testing.
    Problem - folder not there! So I thought "OK Avid have moved it from the suppporting files folder"... search on Mac for AVX. I get plenty of hits including an actual Neat Video AVX folder but no AXX plug ins folder of any description..
    I moved the Neat Video folder to the desktop just in case but that did not solve the issue. I also cannot log into Application Manager - it refuses to let me type into the user and password box (separate issue?)
    John
  • Tue, Mar 28 2017 2:12 PM In reply to
    AFAIK, the AVX plugin folder hasn't moved. And there should be SOME plugins there installed by Avid.
    I would try an uninstall / reinstall and see what happens.
  • Tue, Mar 28 2017 3:41 PM In reply to
    • Posts 11,265
    • Points 231,895
    Kevin Klimek:
    As kevin said, the folder has not moved.  I agree that you should uninstall and reinstall.....
    marianna
  • Tue, Mar 28 2017 9:07 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 759
    • Points 8,960
    @Mondo: to be clear, the exact paths to those folders are:
    1. /Macintosh HD/Library/Application Support/Avid/AVX2_Plugins - user-installed plugins
    2. /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plugins - packaged plugins
    (Note: right-click on the Avid Media Composer app, then select "Show Package Contents" to view.)
    Recommendation: drag the .AVX files in folder option 1 to your Desktop, then relaunch MC.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
  • Wed, Mar 29 2017 3:08 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Isaquit0:
    Thanks  - didn't realise it was packaged which is why it didn't show up in a search. Turned out it was FilmConvertPro that was causing the crash. Will have to see if there is an updated version...
    I am not sure why 1. did not show up in my search though? If it had would have saved me a post..
    John
  • Wed, Mar 29 2017 3:11 PM In reply to
    Perhaps there's an issue with Spotlight on your system.
  • Fri, Mar 31 2017 3:51 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Kevin Klimek:
    I agree it has to be something to do with my system... as I said the install folder for one of the individual plugins showed up but none of the actual plugins or the AVX2 folder.. - all on the MacHD so who knows.
    Anyway turned out there were two plugins that needed upgrading - FilmConvertPro and Neat Video if that helps anyone else.
    John
  • Sat, Apr 1 2017 3:31 PM In reply to
    • Isaac T.
    • Posts 759
    • Points 8,960
    @Kevin Klimek/Mondo: nope, not an issue with the system or Spotlight. Both of these paths are hidden. Wouldn't show up in Spotlight results.
    Also remember. there are two "Library" folders per user:
    1. /Macintosh HD/System/Library
    2. /Macintosh HD/Users/<username>/Library
    "AVX2_Plugins" folder exists in folder "/Macintosh HD/System/Library/".
    macOS ya'll.
  • Sat, Apr 1 2017 4:08 PM In reply to
    Isaquit0:
    That's not correct. There are THREE Library folders, including /Library, and THAT is where the AMA Plugins are:
    /Library/Application Support/Avid/AVX2_Plug-ins/AMA
    I guess Spotlight must ignore that file type, so that's the reason you can't search for it.
  • Sun, Apr 2 2017 12:23 PM In reply to
    • Isaac T.
    • Posts 759
    • Points 8,960
    Spotlight ignores system folders in OS X / macOS by default. Since most AVX2 plugins live there, that's why they don't show up in Spotlight results.
    Of course, you can change that:
    http://apple.stackexchange.com/questions/232404/show-library-folder-and-subfolders-in-spotlight-search
  • Mon, Apr 3 2017 5:50 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Isaquit0:
    Thanks - did not know that. I suppose it is logical if they are constantly changing targets as that would mean a lot more indexing. I'll check out the link - great info..
    John
  • Sun, May 7 2017 6:22 PM In reply to
    • Isaac T.
    • Posts 759
    • Points 8,960
    Updated Media Composer to 8.8.2. MC was stuck with the old "Initialize AVX2 host" message on launch.
    Like everyone else, I had to Force Quit MC, remove AVX files from "/Library/", then re-add them one-by-one until I found the culprits. In my case, it was Red Giant Looks and Misfire. (Extensions troublshooting, anyone?)
    Correcting a previous post, there are indeed three folder locations in OS X / macOS:
    2. /Macintosh HD/System/Library
    3. /Macintosh HD/Users/<username>/Library
    Like Kevin said, AVX2 plugins live here:
    If Marianna or Ralph is reading, a suggestion for engineering: could they check currently installed AVX2 plugins and give a warning of incompatibiity? If MC can't continue loading, present the user with a list of possible culprits, with a button that shoots them straight to that location in Finder. I know it might be a dangerous UX, but the whole no progress indicator is kinda lame.
