Latest post Mon, Aug 22 2016 7:47 PM by Marty. 3 replies.
  • Thu, May 12 2016 9:22 AM
    Legend Audio Communications Error
    Hi Community!
    I need help by our new issue.
    Exception: Legend Audio Communications error, hardware Underrun
    Im getting this error every time i play the timeline. Although it says audio hardware, it does so even with only video on the timeline. Rendering the section helps so maybe its an i/o read/write speed?
    We are running on Media Composer 8.4.5 and ISIS 1000, 10GB network card, where Jumbo packet is disabled. If i enable the jumbo packet, i am getting some errors form isis. I already did Media Composer reinstalation, but no luck.
    Thanks for your help.
    Regards,
    Kristian
  • Wed, Jun 29 2016 7:07 PM In reply to
    • ScaryD
    • Joined on Fri, Jan 23 2009
    • Posts 14
    • Points 160
    Re: Legend Audio Communications Error
    Same here... we're noticing it on two systems.
  • Thu, Jul 28 2016 5:15 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,289
    • Points 28,260
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Are you using the ISIS|1000 v5 software? If at all possilbe I suggest update to the NEXIS|PRO v6.1 software.
    What switch and NIC are you using? What OS? If the media is local, are you not seeing the error?
  • Mon, Aug 22 2016 7:47 PM In reply to
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 942
    • Points 11,020
    No, it's a G-Drive disk connected via USB 3 (USB 3 PCI card).
    I just found this Nexis thread with the search function.
    all different setups in various editing suites. my own: MC 2018.2, OSX 10.12.6, iMac (Retina 5K, 27-inch, 2017), 4,2 GHz Intel Core i7, 40GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
