Latest post Wed, May 11 2016 6:56 PM by Dom Q. Silverio. 8 replies.
Page 1 of 1 (9 items)
  • Thu, May 5 2016 2:24 PM
    • Hoh
    • Joined on Fri, Dec 23 2005
    • Ohio
    • Posts 202
    • Points 2,415
    Mojo DX slot on the z840 HP Workstation ? Thunderbolt card also needs Slot #5.
    I am considering adding the Mojo DX (for SDI in and for Monitoring) on my z840 workstation.
    I have reviewed this site:
    http://avid.force.com/pkb/articles/en_US/Compatibility/HP-Z840-Workstation-Slot-Order-Configuration
    Can I use Slot 3 or 4 for the Mojo DX or is Slot 5 the only slot recommended?  And I need to change some jumpers on the motherboard too?
    UPDATE:  MOJO DX IS RECOMMENDED FOR SLOT5 - BUT SLOT 5 IS ALSO RESERVED FOR THUNDERBOLT CARD. Is anyone running both MOJO/NITRIS DX AND Thunderbolt on z840?
    Darin
    (1): Media Composer 2018.12 ∙ Windows 7 Pro ∙ HP Z840 Xeon E5-2620 v3 2.4GHz ∙ 64GB RAM HP Samsung DDR4 2133 ∙ NVIDIA Quadro K4200 385.69 ∙ Matrox Mojito... [view my complete system specs]
  • Thu, May 5 2016 3:02 PM In reply to
    Re: Mojo DX slot on the z840 HP Workstation ?
    I think you have stumbled onto the Pro Tools config doc. Here's where I'd go to get the specs on an MC setup:
    http://resources.avid.com/supportfiles/config_guides/AVID%20HP%20Z840%20Config%20guide%20-%20Rev%20C.pdf
  • Thu, May 5 2016 3:33 PM In reply to
    • Hoh
    • Ohio
    • Posts 202
    • Points 2,415
    Thanks Job ter Burg!  I need to get a tour of the new website as my searches are getting me where I need to be. :)  thanks!
    Job ter Burg:
  • Wed, May 11 2016 1:18 PM In reply to
    • Hoh
    • Ohio
    • Posts 202
    • Points 2,415
    Okay, it says that MOJO DX needs to go into Slot 5 on the z840.  The Workstation came with Thunderbolt card already in that PCI slot(#5).
    any suggestions?
    Job ter Burg:
    Filed under: , , ,
  • Wed, May 11 2016 2:04 PM In reply to
    Pretty sure that this means you cannot run DX and TB in a blessed setup.
  • Wed, May 11 2016 2:08 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 502
    • Points 6,000
    Don't worry about it.
    Any slot with 4 pcie lanes will do.
    If it boots up, get's detected, and doesn't ask "oh, is this a laptop computer?" you're good to go.
    i says 98% no prob.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Wed, May 11 2016 2:47 PM In reply to
    Lucas, would you recommend keeping the TB or the DX in slot #5?
  • Wed, May 11 2016 5:32 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 502
    • Points 6,000
    Can't say
    The thunderbolt adapter, I think will only work in a specific slot.
    You need an add-on chip or something on the  motherboard for thunderbolt pcie cards.
    Thunderbolt is 4 lanes pci-e + display port. so at least display port shouldn't work in any slot.
    trying will tell. rest assured: you can't break anything.
    The only rule i follow is this: the most expensive pcie card is the furthest away from any hot gpus ;)
    but looking at your specs that ain't a problem.
    Also I'd like to add: if you have an easy choice, stay away from thunderbolt.
    I think that standard is going the way of the dodo, while devices will probaly keep working via usb 3.x
    pcie is the real deal, sits directly on the cpu, not going anywhere.
    if you can get the same device in that standard, slightly rather do that.
  • Wed, May 11 2016 6:56 PM In reply to
    Nitris/Mojo DX will pretty much work in any slot assuming there is enough bandwidth (PCIe2 x4).
    The TB card is designed to work only in a specific slot for each z series model.
