Latest post Thu, Oct 28 2010 8:26 AM by etibamecus. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Oct 26 2005 9:37 PM
    • ericswanson
    • Texas
    • Posts 47
    • Points 595
    Rename Bin Error
    When I create a bin then change the name and hit enter, Avid gives me the error SYS_ERROR, OSERR: -600
    The bin is created and renamed, so no damage is done, just annoying.
    I couldn't find any info on the archived posts.
    Editing on an Xserve (2 x 2.93 GHz quad-core), 12 GB RAM, boot disk is a PCIe SSD) [view my complete system specs]
  • Wed, Oct 26 2005 11:20 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: Rename Bin Error
    You are getting a permissions error. Check the permissions on the Folders in which the bin is being stored.
  • Thu, Oct 27 2005 12:26 AM In reply to
    • ericswanson
    • Texas
    • Posts 47
    • Points 595
    They are all either 777 or 666 and owned by me (everything in /Users/Shared/XpressDV/).
    Why would Avid create a file with the wrong permissions?
  • Thu, Oct 27 2005 12:41 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    I don't know what 777 or 666 means.
    You need to be sure that you have read/write permissions for all of the folders that make up the file tree for your Bin's destination. For instance USER/SHARED/XPRESS PRO/AVID PROJECTS.
    Is this where your bins are being stored/created?
    Have you repaired permissions on that system in a while?
  • Thu, Oct 27 2005 2:47 AM In reply to
    • ericswanson
    • Texas
    • Posts 47
    • Points 595
    Sorry. 777 means everybody can read, write and execute. 666 means everybody can read & write.
    Yes, I do have read/write on my Avid Projects folder where my bins are stored.
    I did repair permissions when this problem first appeared, but I will do it again now and see.
  • Thu, Oct 27 2005 2:54 AM In reply to
    • ericswanson
    • Texas
    • Posts 47
    • Points 595
    Repairing permissions did not fix it.
    Using a new Avid user and opening an existing project did not fix it either.
    Creating a new project didn't help either.
    I also changed the permissions to read/write/execute for the entire contents of /Users/Shared/XpressDV/ which did no good.
  • Thu, Oct 28 2010 8:26 AM In reply to
    Hi, I'l having the same problem, and I checked the permissions too, anybody found a solution on this one ?
