Latest post Mon, Aug 22 2016 3:26 PM by dannybelitz. 4 replies.
  • Thu, Mar 17 2016 12:13 AM
    • Robert B
    • Joined on Sun, Aug 7 2011
    • Los Angeles
    • Posts 83
    • Points 1,005
    Avid 8.5 and relink to file(s)
    I just came across some odd behavior when trying to point some offline AMA clips to the original files. Normally when using the relink to file(s) command, a file browser opens and at the top you see the filename of the file you are searching for. It appears this is not happening. If I select multiple clips, use relink to file(s) -- the file browser window opens, but Avid is not prompting me with the filename I am to relink...so essentially I have no way of knowing which file the Avid wants me to find. Selecting a single clip yields the same behavior, but at least going one at a time you know what clip you're trying to relink.
    Can anyone else replicate this behavior? This particular project is from 2014, so its possible its an old AMA engine incompatibility problem.
    -Robert
    OFFICE: 3.5 GHz Core i7 Late 2013 Imac running OSX 10.11 with 32GB RAM. NVIDIA GTX 780M 4096 MB. Avid Media Composer 8.5/ Pro Tools 12.4 MOBILE: 17"... [view my complete system specs]
  • Thu, Mar 17 2016 3:24 PM In reply to
    Re: Avid 8.5 and relink to file(s)
    I am seeing this as well, also when batch importing. Checking on it now and will escalate if needed.
  • Wed, Aug 3 2016 1:56 PM In reply to
    I've been having the same problem. Is there a workaround of fix for this issue yet? It get's extremely complicated when working with AMAs in 20 different folders.
    Thank you!
  • Wed, Aug 3 2016 2:34 PM In reply to
    This has been fixed in 8.6.1...I don't think it's been fixed in any version of 8.5.x yet.
  • Mon, Aug 22 2016 3:26 PM In reply to
    Great, worked perfectly after update! Thank you!
