Latest post Thu, Mar 3 2016 5:08 PM by WYTCAT. 26 replies.
Page 2 of 2 (27 items) < Previous 1 2
  • Fri, Feb 26 2016 2:59 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    Re: Serious Media Tool issue - Media Tool Bin won't populate
    Martin Jefferson:
    With some help from Matt Mullen, I was able to zero in on the cause of the disappearing media tool - every 10th of a second I was getting a MSMRescan (visible in console). Through a process of trial and error I discovered that I had media in my bg folder that had non-standard characters - a ( and a ! - and by moving those files into the main 1 folder and forcing a database rebuild the issue went away. Media Tool working normally. Hope that helps someone else, and I wanted to publicly apologize to Matt for questioning the brilliance of Facilis Terablock!!
    Martin
    No need to apologize!  Always here to help and I appreciate the kind words.  Glad you got things working!
    -Matt
    -Matt M.
  • Sat, Feb 27 2016 4:10 AM In reply to
    I tried moving all the files from the _bg1 folder and rebuilding the database – but it didn't make any difference.  The info comes into Media Tool – and then momentarily disappears.
    I'm hoping Marianna already has escalated this issue..?
    Best, JIM.
    MC 2019.9.0 Sierra 10.13.6 Westmere Octo 3.46 Mhz 48 GB RAM EVGA GTX 970 FTW GPU SATA RAID array BM DeckLink Mini Monitor 4K [view my complete system specs]
    JAMES BLOKLAND
  • Sat, Feb 27 2016 4:24 PM In reply to
    Jim
    Since Frank's issue was resolved, I have another case going for you.  Case # 02909112
    Support will rech out but if you have your complete spec's like OS etc that would help them out.
    JAMES BLOKLAND
  • Sat, Feb 27 2016 6:37 PM In reply to
    Thanks so much, Marianna!
    specs: OSX 10.11.3, MC8.5
    Hardware: 3.46 Octo core Power Mac tower, 28GB RAM, 5870 graphics card, 256 GB Accelsior PCI SSD boot drive, internal HDs
    project is DNxHD36, all transcoded.
    Best, JIM
    JAMES BLOKLAND
  • Sun, Feb 28 2016 12:45 AM In reply to
    • Posts 11,309
    • Points 232,400
    I added that to the case Jim so support has it now.
    thanks
  • Tue, Mar 1 2016 5:32 PM In reply to
    Updating this - it seems my initial euphoria at fixing it was short-lived. Just moving files out of bg1 is not enough. You have to then delete the empty bg1 folder. That stopped the MSMRescan and returns the media tool to normal. At least, for now! I will try doing anpther background transcode and see if it starts up again.
  • Tue, Mar 1 2016 9:50 PM In reply to
    • Posts 11,309
    • Points 232,400
    Martin
    Keep me posted please...
    Mariana
  • Tue, Mar 1 2016 10:00 PM In reply to
    Hello all:
    I just deleted the _bg1 folder, as per Martin's – and, for the first time since switching to El Cap/MC8.5 – the Media Tool seems to be working as you'd expect.
    Yay!  I'll look forward to Martin's report re what happens when transcoding more AMA files, and the re-creation of the _bg1 folder.
    Best, JIM.
    JAMES BLOKLAND
  • Tue, Mar 1 2016 10:23 PM In reply to
    Got tied up with other stuff, but just did a test. The background transfer did not even create any media, an unknown error occurred - don't you just love those! - but it did create a bg folder on the media drive and sure enough, the MSMRescan started up again and the media tool populates then vanishes. As soon as I delete the bg folder it returns to normal. As a further test, I mounted an ISIS workspace and did a bg transcode to that - not only did the transcode not fail, it also did not cause the MSMRescan and Media Tool shenanigans. Seems like this needs more testing and investigation!
  • Tue, Mar 1 2016 10:29 PM In reply to
    So, Martin...what kind of drive/how is it attached - the one you're having issues with?
    And this problem doesn't exist when you use ISIS shared storage?
  • Thu, Mar 3 2016 1:28 PM In reply to
    Did not have time for testing yesterday. Main storage is Terrablock connected vis ethernet, on TB Manager 6.5.5. The bg folder thing is completely recreatable (if that is a word!). BG transcodes fail, but as soon as the bg folder is created, off it goes with the MSM Rescan. Mounted an ISIS volume and the bg transcode works and does not trigger the problem. I also tested on a PC system also on MC 8.5 and everything worked fine to both TB and ISIS.
  • Thu, Mar 3 2016 5:08 PM In reply to
    • WYTCAT
    • Joined on Mon, Dec 7 2009
    • Germany
    • Posts 16
    • Points 230
    I encountered the same problems as Martin when I transcoded files in the background: As soon as there is a "_bg" folder on the Mediadrive(s) MediaComposer starts an "MSMRescan()" every second or so. You can observe that in the Console window. Then it is not possible to use the Media Tool - the bin populates but immediately the files disappear (for MC does it's scan). It is not the matter of shared or local storage though. I tested with an ethernet-connected ISIS5000 (direct Gigabit Connection) and direct SAS-connected RAID with same results. When I deleted the "_bg" folder, AVID stops the MSMRescan and you can use the Media Tool as normal. Seems MC doesn't tidy up the background folders properly? Tested on different systems (see specs) on Mac OS X 10.11.3 El Capitan and AVID MC 8.5.0. Hope that helps.
    ISIS 5000 • 2x MC 8.7.0, DNxIO, iMac Retina 5K 27" 4.0 Ghz i7 Quad core Late 2015, 32GB, MX395X, OS X 10.11.6 •MC 8.7.0, NitrisDX, MacPro • MC 8.7... [view my complete system specs]
