Latest post Tue, Jun 19 2018 6:52 PM by Brian Berdan, ACE. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Feb 10 2016 1:00 PM
    • SilvaEdit
    • Joined on Wed, Nov 3 2010
    • Posts 94
    • Points 1,135
    8.5 Audio Scrubbing heard without caps lock or shift being on?
    Hi there
    I've been working on an 8 camera multicam sequence inan SD project for the last few todays. Today I noticed that I can hear the audio when scanning the timeline (as the audio scrub sounds) but without shift being pressed or caps lock on. If I press caps lock and turn it on and off again then this stops.
    Possible bug?
  • Wed, Feb 10 2016 7:21 PM In reply to
    • SilvaEdit
    • Posts 94
    • Points 1,135
    Re: 8.5 Audio Scrubbing heard without caps lock or shift being on?
    Also I've noticed that when alt+tab(ing) between Avid and my internet browser - when I alt+tab back to Avid my Caps lock will be on when it wasn't before. I'm on a Mac.
  • Wed, Feb 10 2016 8:26 PM In reply to
    OK...this is bizarre.  I was thinking I was accidently hitting my caps lock key as I usually found it in that state and I thought I was going crazy.
    It's not crzay...I am seeing the CAPS LOCK light up when I switch between Avid and other programs as well.
    Will report...
  • Fri, Apr 15 2016 2:33 PM In reply to
    Here's the scoop for all interested...
    There is now a setting (not sure when it was added, but in 8.5.x for sure) under General called "Enable Caps Lock Protection."
    When checked, this is SUPPOSED to disable caps lock when MC is no longer the focused app. Theoretically, it allows you to keep caps lock on so you can audio scrub, but then turn it off when you switch to another program. It would prevent you from shouting in a Skype window, for example.
    However, it appears to not work as described. Instead, it has the tendancy to enable caps lock within MC when switching back, whether or not it was like that when you left. But if you uncheck it, the phantom caps lock enablign does in fact go away.
  • Fri, Apr 15 2016 3:04 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,194
    • Points 23,515
    Thanks for the update KK I too was seeing this thinking I was doing it withy my fat fingers (though be it very long fingers ) lol
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Fri, May 5 2017 10:46 AM In reply to
    • ChrisH
    • Joined on Thu, Sep 4 2008
    • Posts 113
    • Points 1,410
    I have this issue in 8.6.4.
    I tried the general setting KK describes, but the issue persists. Switching caps lock on and off again fixes it temportarily. Is this a bug?
    Cheers!
    Work: Freelance, so usually a recent-ish Media Composer and ISIS/Unity Home: MC8.x, OS 10.10.5, 15.4" Macbook Pro, 2.8GHz Intel Core i7, Flash HDD... [view my complete system specs]
  • Tue, Jun 19 2018 12:40 AM In reply to
    I had turned on the setting, and it seems like I've noticed the caps lock on a couple times, but not for a few days... BUT, i now can't turn off audio scrub, caps on/caps off, restart.  I hate audio scrub, never use it, and now it's stuck on!
    Any ideas?
    2017 MacBook Pro Aja IO/XT Mojave 10.14.6 MC 2019.12.1 [view my complete system specs]
  • Tue, Jun 19 2018 12:52 AM In reply to
    Ah, went away when I changed sequences. Very odd.
  • Tue, Jun 19 2018 12:55 AM In reply to
    Oops- it was just muted. Really, I've been driving this rig for almost 25 years :)
    Still have audio scrub. Dang.
  • Tue, Jun 19 2018 2:14 PM In reply to
    Have you tried a new Avid user to see if the problem exists there?
  • Tue, Jun 19 2018 6:52 PM In reply to
    Thanks Kevin.  A full computer restart cleared it.
    Silence is golden!
