Latest post Tue, Jan 26 2016 3:28 PM by Vasja. 4 replies.
  • Mon, Jan 25 2016 10:42 PM
    • Vasja
    • Joined on Mon, Jun 24 2013
    • Posts 17
    • Points 195
    Alert Message: "Segmentation Fault" in thread "Main Thread", at address 0x0.
    Hey, I am working on 72 min documentary project. I came to 5 min. and I have this alert Alert Message: "Segmentation Fault" in thread "Main Thread", at address 0x0.  media composer crashes. I can't open the project anymore...what can I do? I had no problem till now with crashes or errors. Using OS El capitan on Macbook pro mid 2015 max. config. and MC7.
    I need to get in to the project there was a lot of work preparing the footage and bins.
    thx.
    Vasja
    Late 2012, iMac i7, 3,4 MHZ, 32 mb RAM, 1TB fusion drive, NVIDIA Geforce GTX680MX 2GB GDDR5, External disk G-RAID 4T Thunderbolt, picture control NEC... [view my complete system specs]
    Filed under: ,
  • Mon, Jan 25 2016 11:30 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 759
    • Points 8,960
    Re: Alert Message: "Segmentation Fault" in thread "Main Thread", at address 0x0.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
  • Tue, Jan 26 2016 12:41 AM In reply to
    • Vasja
    • Posts 17
    • Points 195
    I know...but this thread is to bigggg....I cant even get in to the project. It crashes. I was using it for two-three months without problems with El Capitan. It has to be other problem. Not able to open the project is a bit to far...
  • Tue, Jan 26 2016 2:19 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,146
    • Points 23,890
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hello Vasja,
    Vasja:
       There might be a problem with one of the bins, in Windows you can hold down the ALT key while project is loading, this will keep all the bins closed on start-up, not sure of the equivalent keys in Mac. The post might not get attention because of the unsupported environment.
    Good luck,
    Ralph
  • Tue, Jan 26 2016 3:28 PM In reply to
    • Vasja
    • Posts 17
    • Points 195
    Hay Ralph,
    I have located the "problem"...The reinstallment of the MC7 didn't help so I found with a bit of luck that the bin where audio was located was the problem. I relocated the audio so that he can not link to it and the Project opened. I deleted the audio media mostly the narrator rought draft for checking how it plays with the video. Voice was recorded it in Quick time with Macbook pro inner microphone. I deleted also the bin with jpeg pictures of different size because this is what I was doing when it crashed. When ever I tried to open the project he started to load bins and when he came to audio it crashed.
    Let‘s see if it lasts...but I still dont know what was the couse...corrupeted file, bad audio...or just a bug?
    Vasja
