Latest post Wed, Jan 20 2016 12:23 PM by camoscato. 12 replies.
Page 1 of 1 (13 items)
  • Thu, Jan 14 2016 12:13 PM
    • Trev Burgess
    • Joined on Wed, Jan 4 2006
    • Cardiff UK
    • Posts 29
    • Points 385
    Canon XC10 Codecs
    Just trying to work with footage from the new Canon XC10. 4K works fine with the canon XF codec, but no joy with any flavour of HD. Anyone managed to get it working?
    FCP X sees it just fine, just can't bear to work with it though.
    I'm on Avid 8, Yosemete AMA driver xpfm-3.
    Macpro quad : 64 Gigs memory [view my complete system specs]
    Filed under: , , ,
  • Thu, Jan 14 2016 5:35 PM In reply to
    Re: Canon XC10 Codecs
    What version of MC specifically?
  • Thu, Jan 14 2016 6:57 PM In reply to
    • Trev Burgess
    • Cardiff UK
    • Posts 29
    • Points 385
    Hi
    Its MC to 8.4.0.37275. (MAC)
  • Thu, Jan 14 2016 7:37 PM In reply to
    Have you downloaded the latest Canon AMA plugin?
    The XC10's software page, including the AMA plugin, can be found here.
    Does that work?
  • Thu, Jan 14 2016 7:41 PM In reply to
    The 4K format it shoots to is an AVC format...it might be one that Avid doesn't work with.  XAVC-I Avid works with, but XAVC-S it doesn't. I looked and didn't see what specific AVC format it shoots to.  You might need a third party converter to first convert that format to something Avid works with.  EDITREADY can convert XAVC-S to DNxHR, then avid can AMA Link and consoildate that.  Free demo too.
  • Thu, Jan 14 2016 10:03 PM In reply to
    • Trev Burgess
    • Cardiff UK
    • Posts 29
    • Points 385
    That is the driver I installed. The 4k is fine, HD it says it cant link to the media.
    I tried the ususl, linking to the folder above contents and even tried contents and MXF to see if that was the problem. It seems odd that HD is not supported. The FCP drivers worked just fine.
  • Thu, Jan 14 2016 10:05 PM In reply to
    • Trev Burgess
    • Cardiff UK
    • Posts 29
    • Points 385
    The 4K was OK, its the HD that it just doesn't see. FCP no probs.
    Conversion processes are a nightmare when there is loads of media. I know its an option, but I am trying to avoid it if I possibly can.
  • Thu, Jan 14 2016 10:08 PM In reply to
    Well, if that HD is XAVC-S...Avid doesn't support that yet. FCP might, but not all NLE's support everything.
  • Thu, Jan 14 2016 10:29 PM In reply to
    That might be a question to log at Canon.  If their product page shows that same AMA plugin for that camera, with no corresponding notes as to any limitations, you might want to verify that it supposed to work as advertised.
  • Thu, Jan 14 2016 10:43 PM In reply to
    • Trev Burgess
    • Cardiff UK
    • Posts 29
    • Points 385
    Thanks for the heads up. I'll get on to canon
    • Trev Burgess
    • Cardiff UK
    • Posts 29
    • Points 385
    Thanks. Will do
  • Wed, Jan 20 2016 12:10 PM In reply to
    • Trev Burgess
    • Cardiff UK
    • Posts 29
    • Points 385
    Hi Kevin, I did contact Canon who initially said they thought the HD XAVC-S should work fine. They got straight back however when they checked further they discovered..
    "Avid systems only seem to be able to handle the XF-AVC intra-frame compression that is used for 4K footage, not the XF-AVC long GOP used for HD footage. It seems only Avid systems has this issue."
    Hopefully Avid and Canon (or Sony?) coild have a word with each other to get this codec included? It does appear to be only Avid having issues.
    Cheers
    Trev
    Filed under: , ,
  • Wed, Jan 20 2016 12:23 PM In reply to
    A little more info about XAVCS support here:
    http://community.avid.com/forums/p/136701/776561.aspx
