Latest post Tue, Jan 19 2016 8:54 PM by Marianna. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Jan 14 2016 4:35 AM
    • DylanReeve
    • Auckland, New Zealand
    • Posts 1,680
    • Points 20,460
    • Moderator: MCA Mac
    Unable to Consolidate older seq in 8.4.5 - destBitDepth > 0
    Hi All,
    I encountered an error with 8.4.5 (it was the first 8.x version I'd upgraded this system too from 7.0.4) which I thought I would share because I tracked it down after a long time!
    I was consolidating finished sequences (that had been finished in MC7) and they would fail with an error:
    Assertion failed: destBitDepth > 0
    File: ..\..\src\ColorManagement\ColorSpaceDescriptor.cpp, Line: 365
    Unfortinately neither the error nor the Console offered any hint as to the specific clip at fault... But after much trial and error I discovered it was a title!
    I don't know, ultimately, which software version was used to create the Title Media in question, as it's a common element that's been in use through a number of versions, but simply marking around the entire timeline and re-creating the Title Media was enough to solve the issue (Clip -> Recreate Title Media).
    Hopefully if anyone else comes across this issue then this post will show up in the search results.
    Various systems - including HP Z440 and Z840 workstations Media Composer 2018 [view my complete system specs]
    Dylan Reeve - Edit Geek // Online/Offline Editor // Post Production Supervisor
  • Tue, Jan 19 2016 8:54 PM In reply to
    • Posts 11,221
    • Points 231,295
    Re: Unable to Consolidate older seq in 8.4.5 - destBitDepth > 0
    Dylan
    I am going to create a Knowledge Base article
    thanks for the scoopola
