Latest post Tue, Jan 12 2016 6:15 AM by AndrewAction. 15 replies.
  • Thu, Jan 7 2016 6:19 PM
    • Jonas Cox
    • Joined on Fri, Jan 9 2015
    • Springfield, MA
    • Posts 23
    • Points 275
    DNxHD with alpha *into* After Effects
    I've seen several posts on exporting DNxHD with alpha from AE, but I need to export a DNxHD with alpha from Media Composer for use in AE.  I've tried just about every permutation of settings, and also tried an Animation with alpha, but no luck.  Within AE, I've tried to interpret footage as Straight Matte, Premultiplied, and "Guess" but alpha still doesn't come through.  Have any of you run into this problem?
    I'm on Windows, and my software versions are After Effects CS6 and Media Composer 6.5.4.
    TIA,
    Jonas Cox
    MC 8.9 on Dell 7910 (Windows 7 Professional),with Nitris DX and ISIS [view my complete system specs]
  • Thu, Jan 7 2016 10:11 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,724
    • Points 44,695
    Re: DNxHD with alpha *into* After Effects
    Media Composer does not export anything with an alpha.
    Happy New Year, 2016.
    Jef
    Jef Huey
  • Fri, Jan 8 2016 12:28 AM In reply to
    • Jonas Cox
    • Springfield, MA
    • Posts 23
    • Points 275
    Thanks, but why, then, all the alpha-related settings (millions+, or "None", "Compressed" and "Uncompressed")?
  • Fri, Jan 8 2016 1:31 AM In reply to
    • jef
    • Maryland
    • Posts 3,724
    • Points 44,695
    The DNx .mov codec supports alphas.  It is just MC that does not support export with alpha.
    Only a Product Manager for Avid could tell us why that decision was made.
    Jef
    Jef Huey
  • Fri, Jan 8 2016 4:11 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,774
    • Points 48,230
      Moderator: MCA Mac
    Since MC won't export with Alpha, the only other way is to export the video without alpha, and then display the alpha channel on the timeline and export that. You can use the alpha video in AE to add the alpha channel back to the original video.
    Dave S.
  • Fri, Jan 8 2016 4:19 PM In reply to
    • Jonas Cox
    • Springfield, MA
    • Posts 23
    • Points 275
    Thanks for that workaround.  I'll try that in the future, but for now I'm doing all the compositing in AE.  The reason I had wanted to export alpha from MC is that I like to pull keys with Spectramatte, because I don't have any keying plug-ins in AE.  Instead, I used the basic color key in AE and then rotoscoped/masked out parts that didn't key.
  • Fri, Jan 8 2016 5:40 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,774
    • Points 48,230
      Moderator: MCA Mac
    Jonas Cox:
    For the work flow I describe, you'd create the alpha using Spectramatte and then export out both the original video and the grayscale matte video from MC. Import both videos into AE, put them into a new composition as layers, and set the grayscale matte layer as a Luma matte. There's your keyed video from Spectramatte.
    Dave S.
  • Fri, Jan 8 2016 6:12 PM In reply to
    • jef
    • Maryland
    • Posts 3,724
    • Points 44,695
    Jonas Cox:
    What version of AE are you using?  Keylight has been part of the AE package for a long time.  It is a great keyer.
    Jef
    Jef Huey
  • Fri, Jan 8 2016 6:51 PM In reply to
    • Jonas Cox
    • Springfield, MA
    • Posts 23
    • Points 275
    I see Keylight in there.  I guess that was the one option I hadn't trialed-and-errored.  Thanks!
  • Sat, Jan 9 2016 12:41 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,418
    • Points 97,405
    Keylight is a good keyer, but it has a steep learning curve. It took me a while to get it under control when I first started using it, but it's definitely worth persisting with.
  • Sat, Jan 9 2016 4:14 AM In reply to
    • jef
    • Maryland
    • Posts 3,724
    • Points 44,695
    jwrl:
    Very true.  Still learning it.
    One big thing is that (for my tastes) it's splll suppression makes the fill noisey at times.  So I often just get a good matte then use a different spill suppression tool.
    Jef
    Jef Huey
  • Sat, Jan 9 2016 1:50 PM In reply to
    • scocklin
    • Maryland
    • Posts 672
    • Points 8,015
    I've tried using Spectramatte but always felt Keylight to be a better option. So a long time ago I decided to do all of my keying and graphics in AE and use Avid strictly for editing.  Besides Keylight 1.2 AE CC now has key cleaner,  inner/outer key, linear color key and advance spill supressor.  A lot of good plugins to get you through a badly lit 8 bit green screen shot.
    HP Z800 2x 3.46GHz Hex Core X5690, 96GB Ram, Windows 10, Samsung SSD 1TB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K, Avid MC-2018... [view my complete system specs]
  • Mon, Jan 11 2016 3:20 AM In reply to
    • jwrl
    • Posts 8,418
    • Points 97,405
    I also have the free version of Fusion, and anything I can't readily do with Keylight I do with Primatte.  I've become a real fan of that.
  • Tue, Jan 12 2016 2:09 AM In reply to
    • jef
    • Maryland
    • Posts 3,724
    • Points 44,695
    I was just looking at the Beta Version of Fusion 8 and Primate is SEVERLY limited in that version.  Is that different from the official free version?
    Jef
    Jef Huey
  • Tue, Jan 12 2016 5:33 AM In reply to
    • jwrl
    • Posts 8,418
    • Points 97,405
    Can't really answer that - I'm still running F7 because F8 was crippled in another way.  On F7 the F4 key gives you full screen playback.  On F8 you can't get full screen monitoring unless you have Blackmagic hardware.  So I guess that it's quite possible that they've crippled Primatte too.
