Latest post Wed, May 11 2016 3:47 PM by Brian Mills. 13 replies.
Page 1 of 1 (14 items)
  • Fri, Dec 4 2015 1:59 PM
    • Brian Mills
    • Joined on Tue, Jan 27 2009
    • Media Production Group
    • Posts 80
    • Points 880
    Transcode or Render effects coruption
    I have recently been having problems when I render effects or trascode footage where part of the footage is corrupted.  just a couple of frames or seconds the image is distorted like a digital glitch.  This also occures when I export footage as well. ( same as source) Any one else see a problem like this? Can this be a drive issue? If it is a drive issue what can i do?
    Avid MC 8.4.3 HP Z820 Intel Xeon E5-2650 16GB memory, Nvidia Quatro k4000 Win 7 Prof 64 Matrox [view my complete system specs]
  • Fri, Dec 4 2015 2:11 PM In reply to
    Re: Transcode or Render effects coruption
    Hi.
    We need more information:
    • AMA linked footage or import method?
    • What kind of footage?
    • Are you sending transcodes to your C drive?
    cv
    AVID MEDIA COMPOSER 5.5.3. PC. WINDOWS 7, SP1. 64BIT OPERATING SYSTEM. QUICK TIME VERSION 7.6.9. [view my complete system specs]
    Christian Jhonson
    Avid Ambassador
    christianjhonsoon@hotmail.com
  • Fri, Dec 4 2015 2:32 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    They are ama clips that I am transcoding
    I am rendering to a seperate internal 2TB drive set up for avid media
    Footage is af100 or gh3 cameras avchd
  • Fri, Dec 4 2015 3:03 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    Also this just recently (2 months or so) just started happening
  • Fri, Dec 4 2015 5:18 PM In reply to
    Can you post some screen grabs?
    cv
    Christian Jhonson
    Avid Ambassador
  • Thu, Dec 10 2015 4:50 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    Sorry took a bit to get a render glitch.  This one happened from exporting same as source.  the timeline in avid plays fine.  Not sure if this is avid problem or hard drive problem.
  • Mon, Dec 14 2015 7:10 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    I will upload more as they occur. Some look different than this.
  • Tue, Dec 15 2015 1:18 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,221
    • Points 14,620
    Looks very similar to an issue that I recently escalated with Avid Support; after several attempts, my contact engineer finally managed to get a repro (was hard to do, b/c in my case it appeared only here and there in long multicam sequences (where only AMA-linked AVCHD clips got corrupted during render or transcode))
    See http://community.avid.com/forums/t/132797.aspx and http://community.avid.com/forums/t/132063.aspx
    Will update this thread when I have a bug number
    MC 2018.12.5 (Symphony option)/BCC2019 12.0.4/RED 5.6; BlackMagic Ultrastudio Mini Monitor (11.2); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz -... [view my complete system specs]
  • Wed, Dec 16 2015 2:52 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    Im not sure its that problem.  I got this from export Same as Source.  These files are not spanned files they are short shot broll clips.  This also happens when transcoding in the avid as well.
    Here is the video to see the actual motion. This is an mpg4 render from media encoder but the original has this as well. Didnt want to upload hd.
    https://www.dropbox.com/s/z6g01n745fas9vx/Stpete.mp4?dl=0
    The glitches start around 35 seconds
  • Tue, Jan 5 2016 8:19 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    Here is a short video showing the problem Distorted Video
  • Mon, Jan 11 2016 3:21 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    bump
  • Mon, Jan 11 2016 8:12 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,221
    • Points 14,620
    Brian
    I insist...:watching your video, it looks very similar to the problem I described earlier.
    I have no bug number for it, but it has been reproduced and according to the Avid engineer handling the case, "we are working on this and it  is under investigation"
    The length of the clip/sequence isn't necessarily a factor (it's just that it occurred to me only in that case).
  • Tue, Jan 12 2016 3:22 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    Thanks for the input...hope they can fix this.  Tired of rerendering
  • Wed, May 11 2016 3:47 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    My antivirus software was pingin the footage drives causing the problem. I had the program ignore those drives and bingo have not had a problem for over a few months now!  Hope this helps others.
