Latest post Wed, Dec 16 2015 10:49 PM by P. Fauntleroy. 47 replies.
Page 3 of 4 (48 items) < Previous 1 2 3 4 Next >
  • Thu, Dec 10 2015 12:15 AM In reply to
    • Jomaro
    • Joined on Sat, Jul 10 2010
    • Posts 46
    • Points 685
    Re: Media Composer v8.4.3 | NOW AVAILABLE
    Still the same after the AppMan update... I will do it manually.
    MC 2020.5, Windows 10 2004, Nvidia 1080ti, Intel® Core™i7-7700k Quad Core, 64 GB Ram [view my complete system specs]
  • Thu, Dec 10 2015 12:33 AM In reply to
    • dendawg
    • Joined on Wed, Jul 24 2013
    • New York
    • Posts 12
    • Points 125
    I just manually updated as well. The AppMan is just not cutting it
    Late 2012 iMac i7 Nvidia Graphics 32gb Ram 1TB Fusion drive [view my complete system specs]
  • Thu, Dec 10 2015 8:52 PM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • Southwest, USA
    • Posts 522
    • Points 6,075
    Very Sad.
    Avid MC 6.5.2.1 with 27"iMac 2.8GHz Intel i7 OSX 10.8.3, 12GB memory, ATi Radeon HD 4850, Caldigit Raid [view my complete system specs]
  • Fri, Dec 11 2015 9:43 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,269
    • Points 15,355
    For sure there are things that are more sad in the world at the moment.
    As for updating, I've always been an advocate of a complete uninstall (manually removing stuff the uninstaller doesn't touch), that makes for a neater more stable system.
    The PC side of Avid have had patch installers for years, but on Mac it's still a bit of voodoo magic. So, once bitten...
    - Work: MacPro 2010 3.46Ghz 12 Cores 48Gig RAM, Mojo DX, 10.14.6 - Home: MacBookPro 2.5Ghz quad-i7, 16Gig Mem and SSD OSX 10.11.6 [view my complete system specs]
  • Fri, Dec 11 2015 5:17 PM In reply to
    • bobcat
    • Southwest, USA
    • Posts 522
    • Points 6,075
    Sad that you took a simple statement out of context, on an editing forum, for your own need for attention.
    Peace.
  • Fri, Dec 11 2015 9:01 PM In reply to
    • Posts 11,311
    • Points 232,440
    Always look in the Licensing Forum first peeps.....
    This is pinned to the top of the forum threads....
    Important| MyAvid & AppMan Support Date Inconsistencies
    Unfortunaely, there is a bug in AppMan 2.4.5 ( IT-4894) which will possibly display your old support date on some of the AppMan tabs and generates messages that you need to renew.  Annoying to say the least since it was introduced when AppMan 2.4.5 launched but should not affect MC  8.4.3  - it should work fine.
    If it doesn’t allow you to launch MC 8.4.3, then DEACTIVATE the license within the AppMan and then REACTIVATE it again right away.  if dongle based, download the updater.avd again and update thru AppMan.
    Then launch MC 8.4.3.
    MC looks at the license itself to determine if it will launch a version of the editing software or not based on your My Avid.   If AppMan is showing there old date yet launches MC 8.4.3 then you are fine.   If not then Deactivate/Reactivate from AppMan is required.
    Disregard the messages. Anyone that still has issues should contact support directly and log a case.
  • Sat, Dec 12 2015 12:46 PM In reply to
    • Finbo
    • Joined on Thu, Jan 9 2014
    • Posts 50
    • Points 590
    My App Manager says either connecting and then logging out but actually does neither.
    I have a dongle and I've tried updating by downloading the updater.avd again but this doesn't work either.
    Any ideas??
    The App Manager regularly appears to have problems, when are Avid going to make it more fit for purpose?
  • Sat, Dec 12 2015 9:57 PM In reply to
    • Posts 11,311
    • Points 232,440
    Finbo
    Might be because the updater on your MY Avid needs to be updated.
    Let me create a support case and get them back to you with a manually created updater.avd
    Case
    02855084
  • Sun, Dec 13 2015 10:04 AM In reply to
    • Finbo
    • Posts 50
    • Points 590
  • Tue, Dec 15 2015 1:59 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 1,589
    • Points 19,755
    pierreh:
    Hi Pierre,
    Would you mind describing your method of doing this?  I've always used the uninstaller, but if that doesn't get everything that should be deleted, how best to find these 'hidden' (from Uninstaller anyway) files?
    thanks, Malcolm
    Mac Pro 6-Core 3.3GHz • OSX 10.9.1 • Media Composer v7.0.3 [view my complete system specs]
  • Tue, Dec 15 2015 4:44 PM In reply to
    The Mac Manual uninstall instructions are posted in the START HERE thread at the top of the forums.
  • Wed, Dec 16 2015 1:32 AM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 1,589
    • Points 19,755
    thank you Kevin.  I'll check them out.
    Malcolm
  • Wed, Dec 16 2015 12:26 PM In reply to
    • dendawg
    • New York
    • Posts 12
    • Points 125
    So I did the 8.4.4 update manually last week. I renewed my support plan yesterday, and while the dates are fine on the website I get a warning from the application manager that my support is about to expire and I need to renew. Hope this gets fixed soon.
  • Wed, Dec 16 2015 12:46 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,269
    • Points 15,355
    Here is what I do, based on the START HERE info and more info I gathered over the years:
    - uninstall as much as possible with the Uninstallers found in /Applications/Avid_Uninstallers
    - trash all Avid folders in /Applications and /Applications/Utilities
    - trash Avid folder and content in /Library/Application Support
    - trash Digidesign folder and content in /Library/Application Support
    - trash iZotope folder and content in /Library/Application Support
    - trash PACE folder and content in /Library/Application Support
    - trash com.avid.* files in /Library/LaunchAgents
    - trash com.avid.* files in /Library/LaunchDaemons
    - trash PACE.* files in /Library/LaunchDaemons
    - trash avid.* files in /Library/StartupItems (older versions of Avid)
    - trash avid.* files in /System/Library/Extensions
    - trash Avid folders and content in /Users/Shared/
    (the AvidMediaComposer folder holds your Shared Avid Projects and the Attic, you may want to save those first)
    - trash AVX folder and content in /Users/Shared/
    - trash Avid folders and content in /Users/yourusername/Documents
    - trash Pro Tools folders and content in /Users/yourusername/Documents
    - trash iZotope folders and content in /Users/yourusername/Documents
    For those, hold the ALT key as you open the Go menu in the Finder in order to access the Library hidden folder:
    - trash Avid folder and content in /Users/yourusername/Library/Application Support
    - trash Avid folder and content, and com.avid* files in /Users/yourusername/Library/Preferences
    - trash com.avid folder and content in /Users/yourusername/Library/Saved Application State
    For those you need to use the Go To Folder menu in the Go menu:
    - trash com.avid* files in /private/var/db/receipts
    - trash com.iZotope* files in /private/var/db/receipts
    - trash com.pace* files in /private/var/db/receipts
    There might be more, but that's pretty thorough I think. If you have third party monitoring (AJA, BMD, etc), there might be more stuff to remove. Also, if you have Pro Tools on the same system, it won't be happy once you remove some of its files.
    Once done, I restart the Mac and repair permissions on the boot drive.
    You'll notice that I trash systematically the Avid User folder. I recreate a new user each time I reinstall - I don't have thousands of mods to my keyboard and shortcuts though.
  • Wed, Dec 16 2015 1:40 PM In reply to
    • Runngun
    • Joined on Wed, Dec 16 2015
    • Posts 1
    • Points 5
    Re: Media Composer v8.4.4 | NOW AVAILABLE
    I installed Version 8.4.4 and it's seems fine except it won't link to 4K-MXF files from the FS7!
    The console tells me:
    (Plugin Name = AS-11 Plug-In Avid Technologhy Inc. Version = 1.4.0.6895)does not support xx.mxf
    Is there a new AS-11 AMA Plugin available for download to work with MC 8.4.4 ???
