Latest post Thu, Oct 22 2015 10:41 PM by Igor Ridanovic. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Oct 2 2015 11:29 AM
    • Az Kola
    • Joined on Wed, Nov 16 2011
    • London, UK
    • Posts 275
    • Points 3,280
    Euphonix MC Color with DS11
    Hello All,
    Trying to using the Euphonix MC Color with DS11 but I cannot get this to do anything at all, can't even get 1 key to work. Anyone here has managed to get this doing and any advice much appreciate it
    http://www.flickr.com/photos/azemkola [view my complete system specs]
  • Fri, Oct 2 2015 12:00 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,184
    • Points 23,370
    Re: Euphonix MC Color with DS11
    Hi I have it working On MC8 but there were set up issues at first. Has the system ever worked ? Was there any kind of update? And what version of EUCON are you using?
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Fri, Oct 2 2015 12:19 PM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,280
    This is version 2.5.7, and this is the first time I am trying to get this going, never actually used it.
  • Fri, Oct 2 2015 12:44 PM In reply to
    • Tom Pearson
    • Posts 2,184
    • Points 23,370
    Have you opened EUCON settings and selected the Hardware ?
    Tom Pearson
  • Fri, Oct 2 2015 12:47 PM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,280
    It does say that my DS2 is using it which the Workstation
  • Fri, Oct 2 2015 3:01 PM In reply to
    • Tom Pearson
    • Posts 2,184
    • Points 23,370
    ok There should be a tab that assigns the unit to the computer you ar using as well
    Tom Pearson
  • Fri, Oct 2 2015 3:02 PM In reply to
    • Tom Pearson
    • Posts 2,184
    • Points 23,370
    Sorry for the delays in responding Im in a session and I check breaks
    Tom Pearson
  • Fri, Oct 2 2015 3:05 PM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,280
    Thanks for the replies, much appreciate it. Yes, I am trying to assign, one thing is that not many options to assign and two when I assign something and press the key say F4 e.g. it only shows the EuControl, it doesn't control or effect the Color Correction tools at all.
    I hope that makes sense
  • Fri, Oct 2 2015 3:32 PM In reply to
    • Tom Pearson
    • Posts 2,184
    • Points 23,370
    Hi It sounds like it is not assigning it to the pgm I have to boot and bring my mbp up fully  click on the EUCON  settings select the computer ie:Tom's mac book pro  then Turn on the controller let it populate  and then select the artist controller , Then close the EUCON  app then start MC and teh Controllers will shake hands with mc  also try upgrading to the new EUCON 3.1 Im sure that will help
    Tom Pearson
  • Thu, Oct 22 2015 10:41 PM In reply to
    If you are trying to make it connect to Avid DS, you must do "Install Repair" to load all the drivers and config files after you have connected the hardware.
    If this is Avid Media Composer related, you are in the wrong forum.
    Igor Ridanovic
    www.HDhead.com
